okay - that was awesome. I've seen markus' Id routines - didn't know he boxed it seperately. Here is the result:
52022-02-25 01:09:56.010 am debugsendZigbeeCommands(cmd=[he raw 0x283C 1 0x01 0x0000 {10 00 00 04 00}, delay 2000, he raw 0x283C 1 0x01 0x0000 {10 00 00 05 00}, delay 2000])
dev:3652022-02-25 01:09:56.008 am debugrefresh cmd: [he raw 0x283C 1 0x01 0x0000 {10 00 00 04 00}, delay 2000, he raw 0x283C 1 0x01 0x0000 {10 00 00 05 00}, delay 2000]
dev:3652022-02-25 01:09:55.985 am debugrefresh() model='null'
dev:3652022-02-25 01:09:55.982 am infoupdated()
dev:3652022-02-25 01:09:52.727 am infoCurrent Preferences: [txtEnable:true, reversed:false, autoOffOn:0, logEnable:true, infoLogging:true, enableAutomaticGetInfo:true, debugLogging:false]
dev:3652022-02-25 01:09:51.677 am infoupdated()
dev:3652022-02-25 01:09:40.800 am infoStopped ALL Device Schedules!
dev:3652022-02-25 01:09:37.272 am infoCurrent Preferences: [txtEnable:true, reversed:false, autoOffOn:0, logEnable:true]
dev:3652022-02-25 01:09:36.431 am infoINCOMPLETE - DO NOT SUBMIT THIS - TRY AGAIN: fingerprint model:"null", manufacturer:"null", profileId:"0104", endpointId:"01", inClusters:"null", outClusters:"null"
dev:3652022-02-25 01:09:36.426 am warnOne or multiple pieces of data needed for the fingerprint is missing, requesting it from the device. If it is a sleepy device you may have to wake it up and run this command again. Run this command again to get the new fingerprint.
dev:3652022-02-25 01:09:36.425 am traceApplication: null
dev:3652022-02-25 01:09:36.419 am infoNOT IMPORTANT: Application ID is missing for the fingerprint, requesting it from the device. If it is a sleepy device you may have to wake it up and run this command again. Run this command again to get the new fingerprint.
dev:3652022-02-25 01:09:36.418 am traceModel: null
dev:3652022-02-25 01:09:36.412 am warnModel name is missing for the fingerprint, requesting it from the device. If it is a sleepy device you may have to wake it up and run this command again. Run this command again to get the new fingerprint.
dev:3652022-02-25 01:09:36.411 am traceManufacturer: null
dev:3652022-02-25 01:09:36.405 am warnManufacturer name is missing for the fingerprint, requesting it from the device. If it is a sleepy device you may have to wake it up and run this command again. Run this command again to get the new fingerprint.
dev:3652022-02-25 01:09:36.402 am debugGetting info for Zigbee device...
