This hub gives me a sense of stability and ease of use that I did not have with the other two hubs I evaluated. I've successfully included two test devices the other two hubs had trouble with. The signal passes through a stucco wall between the hub and my target room with ease.
I have a Lutron hub coming, which I will integrate. Gotta have that Caseta Pico switch. I'll use receptacle modules for the under-cabinet lighting. A Sengled Bulb for the range hood.
After the kitchen is done I'll look into the possibility of integrating Blue Iris as a motion detector. If you know how to do that, I'll be happy to hear about it.
Be seeing you...
