Hue indoor sensor luminance sensitivity
May '22 - Is there a way for Hubitat to adjust the luminance sensitivity of a Hue Motion Sensor? In the room where I have mine, the luminance reading from the sensor is "0" in daytime when the lights are off and "6" when the overhead light is on. I have shades on my windows, but the room is light enough for me to read.
Set Lux reporting to happen on a change of 1 lux. That way a change of 0 to 6 detected by your sensor will definitely generate an event, which you can use as an automation trigger.
By default, lux events are generated when there's a change of 10 lux. But the driver permits setting that to 1 lux.
What setting are you using for Lux Reporting?
You might try the log10 functions for better results. Some details can be found here:
What settings are you guys out there using with this device?
Have you left it using the lux change setting or are you using the log10 functions.
If using the log10 functions, which one are you using and typically, what lux change does it report.
I've been playing with these settings but I'm not really seeing much difference.
Also @mike.maxwell which one of the log10 settings is the most sensitive. i.e. report with small light changes.
Many thanks all.
One I think
