Added a decisional catch for the open/close command to deter garage door from redundant commands. As such, if reed sensor is closed (door) and you issue a close command, it will catch it and not engage, also will send info.warn.
Summary
import groovy.json.JsonSlurper
import hubitat.zigbee.clusters.iaszone.ZoneStatus
metadata {
definition (name: "Garage Sensor EX", namespace: "iharyadi", author: "iharyadi", ocfDeviceType: "oic.r.temperature") {
capability "Configuration"
capability "Refresh"
//capability "Battery"
capability "Temperature Measurement"
capability "RelativeHumidityMeasurement"
capability "Illuminance Measurement"
capability "PressureMeasurement"
//capability "Switch"
//capability "SmokeDetector"
//capability "PowerSource"
//capability "CarbonMonoxideDetector"
capability "Sensor"
capability "GarageDoorControl"
command "binaryoutputOff"
command "binaryoutputOn"
MapDiagAttributes().each{ k, v -> attribute "$v", "number" }
attribute "BinaryOutput", "BOOLEAN"
attribute "BinaryInput", "BOOLEAN"
attribute "AnalogInput", "number"
attribute "relativePressure", "number"
fingerprint profileId: "0104", inClusters: "0000, 0001, 0003, 0006, 0402, 0403, 0405, 0400, 0B05, 000F, 000C, 0010", manufacturer: "KMPCIL", model: "RES001", deviceJoinName: "Environment Sensor"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0006, 0402, 0403, 0405, 0400, 0B05, 000F, 000C, 0010,1001", manufacturer: "KMPCIL", model: "RES001", deviceJoinName: "Environment Sensor"
fingerprint profileId: "0104", inClusters: "0000, 0001, 0003, 0006, 0402, 0403, 0405, 0B05, 000F, 000C, 0010", manufacturer: "KMPCIL", model: "RES002", deviceJoinName: "Environment Sensor"
fingerprint profileId: "0104", inClusters: "0000, 0001, 0003, 0006, 0400, 0B05, 000F, 000C, 0010", manufacturer: "KMPCIL", model: "RES003", deviceJoinName: "Environment Sensor"
fingerprint profileId: "0104", inClusters: "0000, 0001, 0003, 0006, 0B05, 000F, 000C, 0010", manufacturer: "KMPCIL", model: "RES004", deviceJoinName: "Environment Sensor"
fingerprint profileId: "0104", inClusters: "0000, 0001, 0003, 0006, 0402, 0403, 0405, 0400, 0B05, 000F, 000C, 0010, 1001", manufacturer: "KMPCIL", model: "RES005", deviceJoinName: "Environment Sensor"
fingerprint profileId: "0104", inClusters: "0000, 0001, 0003, 0006, 0402, 0403, 0405, 0400, 0B05, 000F, 000C, 0010, 0500", manufacturer: "KMPCIL", model: "RES006", deviceJoinName: "Environment Sensor"
preferences {
section("Environment Sensor")
input name:"tempOffset", type:"decimal", title: "Degrees", description: "Adjust temperature by this many degrees in Celcius",
range: "*..*", displayDuringSetup: false
input name:"tempFilter", type:"decimal", title: "Coeficient", description: "Temperature filter between 0.0 and 1.0",
range: "0..1", displayDuringSetup: false
input name:"humOffset", type:"decimal", title: "Percent", description: "Adjust humidity by this many percent",
input name:"illumAdj", type:"decimal", title: "Factor", description: "Adjust illuminace base on formula illum / Factor",
range: "1..*", displayDuringSetup: false
input name:"relativePressOffset", type:"decimal", title: "Relative Pressure", description: "Relative pressure offset in kPA",
range: "0..*", displayDuringSetup: false
input name: "pressureInHg", defaultValue: "false", type: "bool", title: "Report pressure in inhg", description: "",
section("Expansion Sensor")
input name:"enableAnalogInput", type: "bool", title: "Analog Input", description: "Enable Analog Input",
defaultValue: "false", displayDuringSetup: false
input name:"childAnalogInput", type:"text", title: "Analog Input Handler", description: "Analog Input Child Handler",
input name:"enableBinaryInput", type: "bool", title: "Binary Input", description: "Enable Binary Input",
input name:"childBinaryInput", type:"string", title: "Binary Input Handler", description: "Binary Input Device Handler",
input name:"enableBinaryOutput", type: "bool", title: "Binary Output", description: "Enable Binary Output",
input name:"childBinaryOutput", type:"text", title: "Binary Output Handler", description: "Binary Output Child Handler",
section("Serial Device Children")
input name:"childSerialDevices", type:"text", title: "Children[JSON]", description: "Serial Children Handler",
section("Debug Messages")
input name: "logEnabled", defaultValue: "true", type: "bool", title: "Enable info message logging", description: "",
private def Log(message) {
if (logEnabled)
log.info "${message}"
private def NUMBER_OF_RESETS_ID()
return 0x0000;
private def MAC_TX_UCAST_RETRY_ID()
return 0x0104;
private def MAC_TX_UCAST_FAIL_ID()
return 0x0105;
private def NWK_DECRYPT_FAILURES_ID()
return 0x0115;
private def PACKET_VALIDATE_DROP_COUNT_ID()
return 0x011A;
private def PARENT_COUNT_ID()
return 0x011D+1;
private def CHILD_COUNT_ID()
return 0x011D+2;
private def NEIGHBOR_COUNT_ID()
return 0x011D+3;
private def LAST_RSSI_ID()
return 0x011D;
private def BATT_REMINING_ID()
return 0x0021;
private def DIAG_CLUSTER_ID()
return 0x0B05;
private def TEMPERATURE_CLUSTER_ID()
return 0x0402;
private def PRESSURE_CLUSTER_ID()
return 0x0403;
private def HUMIDITY_CLUSTER_ID()
return 0x0405;
private def ILLUMINANCE_CLUSTER_ID()
return 0x0400;
private def POWER_CLUSTER_ID()
return 0x0001;
private def BINARY_INPUT_CLUSTER_ID()
return 0x000F;
private def BINARY_OUTPUT_CLUSTER_ID()
return 0x0010;
private def ANALOG_INPUT_CLUSTER_ID()
return 0x000C;
private def SENSOR_VALUE_ATTRIBUTE()
return 0x0000;
private def SERIAL_TUNNEL_CLUSTER_ID()
return 0x1001;
private def MapDiagAttributes()
def result = [(CHILD_COUNT_ID()):'Children',
(NEIGHBOR_COUNT_ID()):'Neighbor',
(NUMBER_OF_RESETS_ID()):'ResetCount',
(MAC_TX_UCAST_RETRY_ID()):'TXRetry',
(MAC_TX_UCAST_FAIL_ID()):'TXFail',
(LAST_RSSI_ID()):'RSSI',
(NWK_DECRYPT_FAILURES_ID()):'DecryptFailure',
(PACKET_VALIDATE_DROP_COUNT_ID()):'PacketDrop']
return result;
private def createDiagnosticEvent( String attr_name, type, value )
def result = [:]
result.name = attr_name
result.translatable = true
def converter = [(DataType.INT8):{int val -> return (byte) val},
(DataType.INT16):{int val -> return val},
(DataType.UINT16):{int val -> return (long)val}]
result.value = converter[zigbee.convertHexToInt(type)]( zigbee.convertHexToInt(value));
result.descriptionText = "${device.displayName} ${result.name} is ${result.value}"
return createEvent(result)
private def parseDiagnosticEvent(def descMap)
def attr_name = MapDiagAttributes()[zigbee.convertHexToInt(descMap.attrId)];
if(!attr_name)
return null;
return createDiagnosticEvent(attr_name, descMap.encoding, descMap.value)
private def createPressureEvent(float pressure)
String unit = pressureInHg ? "inhg": "kPa"
def result = [:]
result.name = "pressure"
result.unit = unit
result.value = (pressureInHg ? (pressure/3.386):pressure).round(2)
result.descriptionText = "${device.displayName} ${result.name} is ${result.value} ${result.unit}"
if (relativePressOffset && relativePressOffset != 0)
pressure = pressure+relativePressOffset
def relPEvent = [:]
relPEvent.name = "relativePressure"
relPEvent.translatable = true
relPEvent.unit = unit
relPEvent.value = (pressureInHg ? (pressure/3.386):pressure).round(2)
relPEvent.descriptionText = "${device.displayName} ${result.name} is ${result.value} ${result.unit}"
sendEvent(relPEvent)
return result
private def parsePressureEvent(def descMap)
if(zigbee.convertHexToInt(descMap.attrId) != SENSOR_VALUE_ATTRIBUTE())
return null
float pressure = (float)zigbee.convertHexToInt(descMap.value) / 10.0
return createPressureEvent(pressure)
private def createHumidityEvent(float humidity)
def result = [:]
result.name = "humidity"
result.value = humidity
result.unit = "%"
if (humOffset) {
result.value = result.value + humOffset
result.value = result.value.round(2)
return result
private def parseHumidityEvent(def descMap)
return null
float humidity = (float)zigbee.convertHexToInt(descMap.value)/100.0
return createHumidityEvent(humidity)
private def createIlluminanceEvent(int illum)
def result = [:]
result.name = "illuminance"
result.unit = "Lux"
if(!illumAdj || illumAdj < 1.0)
double val = 0.0
if(illum > 0)
val = 10.0 ** (((double) illum -1.0)/10000.0)
result.value = val.round(2)
else
result.value = ((double)illum / illumAdj).toInteger()
return result
def parseIlluminanceEvent(def descMap)
return null
int res = zigbee.convertHexToInt(descMap.value)
return createIlluminanceEvent(res)
private def createTempertureEvent(float temp)
def result = [:]
result.name = "temperature"
result.value = temperature
result.unit = "°${location.temperatureScale}"
result.value = convertTemperatureIfNeeded(temp,"c",1)
return result
private float adjustTemp(float val)
if (tempOffset) {
val = val + tempOffset
if(tempFilter)
if(state.tempCelcius)
val = tempFilter*val + (1.0-tempFilter)*state.tempCelcius
state.tempCelcius = val
return val
private def parseTemperatureEvent(def descMap)
float temp = adjustTemp((hexStrToSignedInt(descMap.value) / 100.00).toFloat())
return createTempertureEvent(temp)
private def createBinaryOutputEvent(boolean val)
def result = [:]
result.name = "BinaryOutput"
result.value = val ? "true" : "false"
return result
def parseBinaryOutputEvent(def descMap)
def present_value = descMap.attrId?.equals("0055")?
descMap.value:
descMap.additionalAttrs?.find { item -> item.attrId?.equals("0055")}?.value
if(!present_value)
return null
return createBinaryOutputEvent(zigbee.convertHexToInt(present_value) > 0)
private def createAnalogInputEvent(float value)
def result = [:]
result.name = "AnalogInput"
result.value = value
result.unit = "Volt"
return result
private Float ConvertStringIntBitsToFloat(String val)
Long i = Long.parseLong(val, 16);
Float f = Float.intBitsToFloat(i.intValue());
return f;
def parseAnalogInputEvent(def descMap)
def adc;
def vdd;
if(descMap.attrId?.equals("0103"))
adc = descMap.value
else if (descMap.attrId?.equals("0104"))
vdd = descMap.value
else
adc = descMap.additionalAttrs?.find { item -> item.attrId?.equals("0103")}.value
vdd = descMap.additionalAttrs?.find { item -> item.attrId?.equals("0104")}.value
if(vdd)
state.lastVdd = (((float)zigbee.convertHexToInt(vdd)*3.45)/0x1FFF)
if(!adc)
return null
float volt = 0;
if(state.lastVdd)
volt = (zigbee.convertHexToInt(adc) * state.lastVdd)/0x1FFF
return createAnalogInputEvent(volt)
def open()
//log.info device.currentValue("door")
if ((device.currentValue("door"))== "closed")
log.info "${device} is being opened"
runInMillis(1500, binaryoutputOff)
binaryoutputOn()
else
log.warn "Garage door was already open, did not proceed with open command"
def close()
if ((device.currentValue("door"))== "open")
log.info "${device} is being closed"
binaryoutputOn()
else
log.warn "Garage door was already closed, did not proceed with close command"
private def createBinaryInputEvent(boolean val)
def result = [:]
result.name = "BinaryInput"
result.value = val
return result
def parseBinaryInputEvent(def descMap)
def value = descMap.attrId?.equals("0055") ?
descMap.value :
descMap.additionalAttrs?.find { item -> item.attrId?.equals("0055")}.value
if(!value)
return null
return createBinaryInputEvent(zigbee.convertHexToInt(value)==0)
private def reflectToChild(String childtype, String description)
if(!childtype)
return
def childDevice = getChildDevice("${device.deviceNetworkId}-$childtype")
if(!childDevice)
return
def childEvent = childDevice.parse(description)
if(!childEvent)
return
childDevice.sendEvent(childEvent)
private def reflectToSerialChild(def data)
def zigbeeAddress = device.getZigbeeId()
Integer page = zigbee.convertHexToInt(data[1])
def childDevice = getChildDevice("$zigbeeAddress-SerialDevice-$page")
if(!childDevice)
return
def childEvent = childDevice.parse(data)
if(!childEvent)
return
private def createBattEvent(int val)
def result = [:]
result.name = "battery"
result.value = val/2
result.unit = "%"
return result
def parseBattEvent(def descMap)
def value = descMap?.attrId?.equals(zigbee.convertToHexString(BATT_REMINING_ID(),4)) ?
descMap.value :
null
if(!value)
return null
return createBattEvent(zigbee.convertHexToInt(value))
def parseCustomEvent(String description)
def event = null
if(description?.startsWith("read attr - raw:"))
def descMap = zigbee.parseDescriptionAsMap(description)
if(descMap?.cluster?.equals(zigbee.convertToHexString(TEMPERATURE_CLUSTER_ID(),4)))
event = parseTemperatureEvent(descMap)
else if(descMap?.cluster?.equals(zigbee.convertToHexString(DIAG_CLUSTER_ID(),4)))
event = parseDiagnosticEvent(descMap);
else if(descMap?.cluster?.equals(zigbee.convertToHexString(PRESSURE_CLUSTER_ID(),4)))
event = parsePressureEvent(descMap);
else if(descMap?.cluster?.equals(zigbee.convertToHexString(HUMIDITY_CLUSTER_ID(),4)))
event = parseHumidityEvent(descMap);
else if(descMap?.cluster?.equals(zigbee.convertToHexString(ILLUMINANCE_CLUSTER_ID(),4)))
event = parseIlluminanceEvent(descMap);
else if(descMap?.cluster?.equals(zigbee.convertToHexString(BINARY_INPUT_CLUSTER_ID(),4)))
event = parseBinaryInputEvent(descMap);
//log.debug ("$event")
sendEvent (name:"door",value:(("$event.value")== "true")?"closed":"open")
//log.info ("$event.value")
reflectToChild(childBinaryInput,description)
else if(descMap?.cluster?.equals(zigbee.convertToHexString(ANALOG_INPUT_CLUSTER_ID(),4)))
event = parseAnalogInputEvent(descMap)
reflectToChild(childAnalogInput,description)
else if(descMap?.cluster?.equals(zigbee.convertToHexString(BINARY_OUTPUT_CLUSTER_ID(),4)))
event = parseBinaryOutputEvent(descMap)
reflectToChild(childBinaryOutput,description)
else if(descMap?.cluster?.equals(zigbee.convertToHexString(POWER_CLUSTER_ID(),4)))
event = parseBattEvent(descMap)
return event
boolean parseSerial(String description)
if(!description?.startsWith("catchall:"))
return false
if( !(descMap.profileId?.equals("0104") ) )
return false
if( !(descMap.clusterInt?.equals(SERIAL_TUNNEL_CLUSTER_ID()) ) )
return false
if( !(descMap.command?.equals("00") ) )
return false
if(!descMap.data)
return false
reflectToSerialChild(descMap.data)
return true
private boolean parseIasMessage(String description) {
if (description?.startsWith('enroll request'))
Log ("Sending IAS enroll response...")
def cmds = zigbee.enrollResponse()
cmds?.collect{ sendHubCommand(new hubitat.device.HubAction(it,hubitat.device.Protocol.ZIGBEE) ) };
return true
else if (description?.startsWith('zone status '))
ZoneStatus zs = zigbee.parseZoneStatus(description)
String[] iasinfo = description.split(" ")
int x = hexStrToSignedInt(iasinfo[6])
def resultMap;
if(zs.alarm1)
if(x == 0)
resultMap = createEvent(name: "smoke", value: "detected")
else
resultMap = createEvent(name: "carbonMonoxide", value: "detected")
sendEvent(resultMap)
else
resultMap = createEvent(name: "smoke", value: "clear")
resultMap = createEvent(name: "carbonMonoxide", value: "clear")
if(zs.ac)
resultMap = createEvent(name: "powerSource", value: "battery")
else
resultMap = createEvent(name: "powerSource", value: "main")
return true
return false
// Parse incoming device messages to generate events
Log("parse: $description")
if(parseIasMessage(description))
return
event = parseCustomEvent(description)
if(event)
sendEvent(event)
return
def event = zigbee.getEvent(description)
if(event)
sendEvent(event)
return
if(parseSerial(description))
return
Log("DID NOT PARSE MESSAGE : $description")
def off() {
def on() {
def sendCommandPDelay(data)
return data
def sendCommandP(def cmd)
runIn(0, sendCommandPDelay, [overwrite: false,data: cmd])
def sendToSerialdevice(byte[] serialCmd)
String serial = serialCmd.encodeHex().toString()
return zigbee.command(SERIAL_TUNNEL_CLUSTER_ID(), 0x00,[:],0,serial)
def command(Integer Cluster, Integer Command, String payload)
return zigbee.command(Cluster,Command,payload)
def command(Integer Cluster, Integer Command)
return zigbee.command(Cluster,Command)
def readAttribute(Integer Cluster, Integer attributeId, Map additionalParams)
return zigbee.readAttribute(Cluster, attributeId, additionalParams)
def readAttribute(Integer Cluster, Integer attributeId)
return zigbee.readAttribute(Cluster, attributeId)
def writeAttribute(Integer Cluster, Integer attributeId,
Integer dataType, Integer value,
return zigbee.writeAttribute(Cluster, attributeId,
dataType, value,
additionalParams)
Integer dataType, Integer value)
dataType, value)
def configureReporting(Integer Cluster,
Integer attributeId, Integer dataType,
Integer minReportTime, Integer MaxReportTime,
Integer reportableChange,
return zigbee.configureReporting( Cluster,
attributeId, dataType,
minReportTime, MaxReportTime,
reportableChange,
aditionalParams)
Integer reportableChange)
reportableChange)
Integer minReportTime, Integer MaxReportTime)
minReportTime, MaxReportTime)
def binaryoutputOff()
zigbee.writeAttribute(0x0010, 0x0055, DataType.BOOLEAN, 1)
def binaryoutputOn()
zigbee.writeAttribute(0x0010, 0x0055, DataType.BOOLEAN, 0)
private def refreshExpansionSensor()
def cmds = []
def mapExpansionRefresh = [[0x0010,enableBinaryOutput,0x0055],
[0x000F,enableBinaryInput,0x0055],
[0x000C, enableAnalogInput,0x00104],
[0x000C, enableAnalogInput,0x00103]]
mapExpansionRefresh.findAll { return it[1] }.each{
cmds = cmds + zigbee.readAttribute(it[0],it[2])
return cmds
private def refreshOnBoardSensor()
def model = device.getDataValue("model")
def cmds = [];
def mapRefresh = ["RES001":[TEMPERATURE_CLUSTER_ID(), HUMIDITY_CLUSTER_ID(), PRESSURE_CLUSTER_ID(),ILLUMINANCE_CLUSTER_ID()],
"RES002":[TEMPERATURE_CLUSTER_ID(), HUMIDITY_CLUSTER_ID(), PRESSURE_CLUSTER_ID()],
"RES003":[ILLUMINANCE_CLUSTER_ID()],
"RES005":[TEMPERATURE_CLUSTER_ID(), HUMIDITY_CLUSTER_ID(), PRESSURE_CLUSTER_ID(),ILLUMINANCE_CLUSTER_ID()],
"RES006":[TEMPERATURE_CLUSTER_ID(), HUMIDITY_CLUSTER_ID(), PRESSURE_CLUSTER_ID(),ILLUMINANCE_CLUSTER_ID()]]
mapRefresh[model]?.each{
cmds = cmds + zigbee.readAttribute(it,SENSOR_VALUE_ATTRIBUTE());
return cmds
private def refreshDiagnostic()
def cmds = [];
MapDiagAttributes().each{ k, v -> cmds += zigbee.readAttribute(DIAG_CLUSTER_ID(), k) }
return cmds
private def refreshBatt()
return zigbee.readAttribute(POWER_CLUSTER_ID(), BATT_REMINING_ID())
def refresh() {
Log ("Refresh")
state.lastRefreshAt = new Date(now()).format("yyyy-MM-dd HH:mm:ss", location.timeZone)
return refreshOnBoardSensor() +
refreshExpansionSensor() +
refreshDiagnostic() +
refreshBatt()
private def reportBME280Parameters()
return [[TEMPERATURE_CLUSTER_ID(),DataType.INT16, 5, 300, 10],
[HUMIDITY_CLUSTER_ID(),DataType.UINT16, 5, 301, 100],
[PRESSURE_CLUSTER_ID(),DataType.UINT16, 5, 302, 2]]
private def reportTEMT6000Parameters()
return [[ILLUMINANCE_CLUSTER_ID(),DataType.UINT16, 5, 303, 500]]
private String swapEndianHex(String hex) {
reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
int i = 0;
int j = array.length - 1;
byte tmp;
while (j > i) {
tmp = array[j];
array[j] = array[i];
array[i] = tmp;
j--;
i++;
return array
private def configureIASZone()
def cmds = []
cmds += "zdo bind 0x${device.deviceNetworkId} 0x${device.endpointId} 0x01 0x0500 {${device.zigbeeId}} {}"
cmds += "delay 1500"
cmds += "he wattr 0x${device.deviceNetworkId} 0x${device.endpointId} 0x0500 0x0010 0xf0 {${swapEndianHex(device.hub.zigbeeId)}}"
cmds += "delay 2000"
return cmds
def configure() {
Log("Configuring Reporting and Bindings.")
state.remove("tempCelcius")
def mapConfigure = ["RES001":reportBME280Parameters()+reportTEMT6000Parameters(),
"RES002":reportBME280Parameters(),
"RES003":reportTEMT6000Parameters(),
"RES005":reportBME280Parameters()+reportTEMT6000Parameters(),
"RES006":reportBME280Parameters()+reportTEMT6000Parameters()]
def cmds = [];
mapConfigure[model]?.each{
cmds = cmds + zigbee.configureReporting(it[0], SENSOR_VALUE_ATTRIBUTE(), it[1],it[2],it[3],it[4])
cmds += zigbee.configureReporting(POWER_CLUSTER_ID(), BATT_REMINING_ID(), DataType.UINT8,60,307,4)
if(model == "RES006")
cmds = cmds + configureIASZone()
cmds = cmds + refresh();
return cmds
private def createChild(String childDH, String component)
if(!childDH)
return null
def childDevice = getChildDevice("${device.deviceNetworkId}-$childDH")
if(!childDevice)
childDevice = addChildDevice("iharyadi",
"$childDH",
"${device.deviceNetworkId}-$childDH",
[label: "${device.displayName} $childDH",
isComponent: false,
componentName: component,
componentLabel: "${device.displayName} $childDH"])
return childDevice?.configure_child()
private def updateExpansionSensorSetting()
def cmds = []
def mapExpansionEnable = [[0x0010,enableBinaryOutput,DataType.BOOLEAN,0x0055],
[0x000F,enableBinaryInput,DataType.BOOLEAN,0x0055],
[0x000C, enableAnalogInput,DataType.UINT16,0x0103]]
mapExpansionEnable.each{
cmds = cmds + zigbee.writeAttribute(it[0], 0x0051, DataType.BOOLEAN, it[1]?1:0)
if(!it[1])
cmds = cmds + zigbee.configureReporting(it[0], it[3], it[2], 0xFFFF, 0xFFFF,1)
def mapExpansionChildrenCreate = [[enableBinaryOutput,childBinaryOutput,"BinaryOutput"],
[enableBinaryInput,childBinaryInput,"BinaryInput"],
[enableAnalogInput,childAnalogInput,"AnalogInput"]]
mapExpansionChildrenCreate.findAll{return (it[0] && it[1])}.each{
cmds = cmds + createChild(it[1],it[2])
return cmds
private def createSerialDeviceChild(String childDH, Integer page)
createSerialDeviceChildWithLabel(childDH,page, "${device.displayName} SerialDevice-$page")
def createSerialDeviceChildWithLabel(String childDH, Integer page, String label)
if(!childDH)
return null
if(!childDevice)
"$childDH",
"$zigbeeAddress-SerialDevice-$page",
[label: "${label}",
isComponent: false,
componentName: "SerialDevice-$page",
componentLabel: "${device.displayName} SerialDevice-$page",
pageNumber: page])
private def updateSerialDevicesSetting()
def cmds = []
if(!childSerialDevices)
return cmds;
def jsonSlurper = new JsonSlurper()
def serialchild = jsonSlurper.parseText(childSerialDevices)
serialchild.each{
createSerialDeviceChild(it.DH, it.Page)
cmds += "zdo bind 0x${device.deviceNetworkId} 0x${device.endpointId} 0x01 0x${Integer.toHexString(SERIAL_TUNNEL_CLUSTER_ID())} {${device.zigbeeId}} {}"
return cmds
def updated() {
Log("updated():")
if (!state.updatedLastRanAt || now() >= state.updatedLastRanAt + 2000) {
state.updatedLastRanAt = now()
def cmds = updateExpansionSensorSetting()
if(device.getDataValue("model") == "RES005")
cmds += updateSerialDevicesSetting()
cmds += refresh()
return cmds
else {
Log("updated(): Ran within last 2 seconds so aborting.")
