I'm sure I' m missing something obvious, but in my Safety Monitor setup page there's no option to specify which device to use to arm away through the use pf a physical button.
I've followed the documentation and my page just does not have the option for 'Arm away with this button'. the only instance of the word 'button' on my page is 'Hubitat Safety Monitor also supports arming and disarming with button devices', which does indeed show my several Iris 1st Gen Power Outlets/wall worts.
Is the problem that possibly some types of devices can be used to disarm, but not arm? And therefore the option doesn't even present itself to me since those are the only type of button devices I own?
Do you have the away setup complete? It will be present once you create the Away intrusion setup. If you don't have the setup complete it won't display all the options.
For anyone else wth a similar potential problem, this was a good thread with lots of details:
At one point the poster had one of my problems, which is that even trying to 'arm' through the web UI didn't do anything. Unfortunately, he says an update last year helped him, though I am already up-to-date.
With the discovery I'm not even able to arm intrusion within the web UI (though disarming smoke/CO monitoring in the web UI seems to work), I'm now thinking my problem is bigger than just not being able to elect buttons on power plugs to be responsible for arming.
I use the Hubitat dashboard and use ST presence senors to automatically arm & disarm only problem batteries don't last a long time. Back to the dashboard app on my phone you can arm & disarm from there, hope this help you.
Apologies if I'm missing something obvious. Does it appear from this screenshot that I have successfully removed the 'arm by mode' option and should therefore see the option to arm by button?
Yeah I'd definitely done that. In fact, for my first hour or so of troubleshooting I never had any auto arm events; I only ended up adding some in a last ditch effort to get something to fire.
So, HSM doesn't work at all?!?!? Why didn't you start with that?!?!? You should either remove HSM all together and start over or contact support@hubitat.com
It's not that I don't want to its that if HSM isn't working within the WebUI there's nothing I can do to help you. Your best bet would be to re-install the app (which is what I would do if it was working like that) or contact support. If the option just isn't showing up, there's not much else to do.
Do you have any button devices installed on your system? Devices that specifically have the Pushable Button capability? Try adding a virtual button device and see what happens.
