Hi All,
I need some much needed help and would be grateful for some suggestions.
I have a split wardrobe that I share with the missus. I would like to illuminate either side for her or me depending on who has opened what door. I have contact sensors installed on his and hers doors. I have also 1 Lifx Z LED strip across the entire length of the wardrobe. I went for the lifx strip because of the ability to control individual zones enabling me to have a have on have off setup. Using Scenes, i can divide the strip into left and right. I would like to have it setup so,
Door 1 Open Door 2 Shut = Scene 1 (Left Zones) On.
Door 1 Shut Door 2 Open = Scene 2 (Right Zones) On.
Door 1 Open Door 2 Open = Scene 3 (All) On.
Door 1 Shut Door 2 Shut = All Off.
I know that i will probably need some virtual switches in Hubitat to use with IFTTT but not sure on the logic as I am still fairly inexperienced at using rule machine. I would like the lights to swap between these scenes depending on the opening and closing of the different doors at different times.
I realise that this would be loads simpler with 2 separate strips but the aren't cheap.
