C-8 - 2.4.3.137
I've been trying to match up my apps and getting the following error. I don't know when this problem started so I'm not sure what is causing it.
C-8 - 2.4.3.137
Hmm... That is interesting that it is failing on the Community repository.
What version of HPM are you running, Dominic's original or @csteele 's masterpiece ![]()
Just an FYI.. this probably doesn't belong under Get Help / Apps given this is a Community developed App, as much as (part of us) we would like to see it built in
Mine does the same thing. But if you wait a bit it should refresh and show match up complete and if there are any needing to be matched.
Where might I find that?
By masterpiece all I meant was that he took Dominic's version and tweaked it...
I wouldn't want to overstate the difference compared to the original... While not downplaying the fact that someone stepped up to maintain the Community's key offering... i.e. we should all thank @csteele .... buy him a coffee, mention him in our will...
Admittedly none of which I have done...Hmm.... I should probably update my will... ![]()
I am using Dominick Meglio v1.9.3
I took @CapWoody advise and waited and it eventually completed.
This has been fixed. However the MHedish repo had to be quarantined due to JSON errors. (extra , at the end)
