Thanks for the input, y'all. It sounds like InfluxDB is worth a shot, at least in parallel with the MySQL database. I'm already looking forward to checking out all of the good stuff here and in other posts on the subject.
With the new Maker API POST Url change, I'm going to redesign my NodeRed flow to take advantage of it. I'll post the new flow when I get it done.
I really appreciate the HE team upgrading the Maker Api for better "bidirectional" support. Being able to selectively push out data rather than having to use the floodgate approach of websocket (PLEASE do not remove btw) is an awesome option. I dabbled with the new Maker Api on my dev hub during the beta and was very impressed with how well it worked. It was only for a few devices as a test but I look forward to using on my main hub and seeing how it holds up.
I also really look forward to how you approach utilizing this as you are my NR/database guru.
Show us the way oh wise one.
I keep telling my coworkers that and they just laugh at me. lol
Do you have any recommendations for completely code illiterate people (like myself) to any sort of learning this for dummies area. Maybe Youtube or other form of documentation.
I recently got a Qnap Nas and would like to implement some of this stuff, and can follow your instructions above, but I think first I should familiarize myself with some of the terminology and areas you're instructing on above first.
@stephack could you share the json file for your nodered flow and explain a bit more how you got your log to look so nice in a spreadsheet?
I'll have to export it for you tomorrow when I can get to my desktop.
To be honest, I'm not sure I remember all the steps but it really boils down to how comfortable you are with data importing and manipulation in excel. I'm simply importing the log files I created into excel as a delimited text file and then applying some formatting, etc. I'll try to list as many steps as I can remember tomorrow as well.
Quick node by node breakdown
- pulls data from the logsocket
- extracts the data I wanted and converts to delimited text file (I chose ||| as this shouldn't appear anywhere in the logs normally)
- fixes anomalies that occurred when logs contains special characters or actual html.
- saves the log file to location of choice
5 - 9. sets the maximum size of log files, when reached, archives and created a new log file
10-12. sets maximum number of logs files to keep and deletes the oldest.
Log size and number of logs can be easily changed to what you need.
Below is my exported flow for logging. You will need to point the first node to the logsocket you created and replace the log path and archive path with your specific locations.
Excel details to come later.
"id": "9c740a.039f3bf8",
"type": "file",
"z": "43aea04d.3bd6e",
"name": "Ouptut to he_logs.log",
"filename": "/yourPath/he_logs.log",
"appendNewline": true,
"createDir": false,
"overwriteFile": "false",
"encoding": "none",
"x": 820,
"y": 260,
"wires": [
"6b7bba59.42d0c4"
"id": "6b7bba59.42d0c4",
"type": "fs-ops-size",
"name": "Log Size",
"path": "/yourPath",
"pathType": "str",
"filename": "he_logs.log",
"filenameType": "str",
"size": "filesize",
"sizeType": "msg",
"x": 260,
"y": 340,
"wires": [
"b0409461.ec2518"
"id": "cd31194d.e094c8",
"type": "fs-ops-move",
"name": "Archive Log",
"sourcePath": "/yourPath",
"sourcePathType": "str",
"sourceFilename": "he_logs.log",
"sourceFilenameType": "str",
"destPath": "/yourArchivePath",
"destPathType": "str",
"destFilename": "newname",
"destFilenameType": "msg",
"link": false,
"x": 930,
"y": 340,
"wires": [
"da05758.c7ae488"
"id": "da05758.c7ae488",
"type": "fs-ops-dir",
"name": "# of Logs",
"path": "/home/stephack/backup/nodered/main/logs/log_archive",
"pathType": "str",
"filter": "*",
"filterType": "str",
"dir": "files",
"dirType": "msg",
"x": 400,
"y": 420,
"wires": [
"73b6cf78.d6a33"
"id": "7d3a757b.d97bdc",
"type": "fs-ops-delete",
"name": "Del Oldest Log",
"path": "/yourArchivePath",
"pathType": "str",
"filename": "files[0]",
"filenameType": "msg",
"x": 720,
"y": 420,
"wires": [
"id": "ff5df71f.907cc8",
"type": "moment",
"name": "",
"topic": "",
"input": "timestamp",
"inputType": "msg",
"inTz": "America/New_York",
"adjAmount": 0,
"adjType": "days",
"adjDir": "add",
"format": "YYYY-MM-DD_hh-mm-ss",
"locale": "en_US",
"output": "newname",
"outputType": "msg",
"outTz": "America/New_York",
"x": 620,
"y": 340,
"wires": [
"7fd311fb.e9d21"
"id": "7fd311fb.e9d21",
"type": "string",
"name": "\".log\"",
"methods": [
"name": "append",
"params": [
"type": "str",
"value": ".log"
"prop": "newname",
"propout": "newname",
"object": "msg",
"objectout": "msg",
"x": 790,
"y": 340,
"wires": [
"cd31194d.e094c8"
"id": "b0409461.ec2518",
"type": "switch",
"name": "Archive If > 2MB",
"property": "filesize",
"propertyType": "msg",
"rules": [
"t": "gt",
"v": "2000000",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 420,
"y": 340,
"wires": [
"ff5df71f.907cc8"
"id": "73b6cf78.d6a33",
"type": "switch",
"name": "15 Log Limit",
"property": "files.length",
"rules": [
"t": "gte",
"v": "15",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 550,
"y": 420,
"wires": [
"7d3a757b.d97bdc"
"id": "62fe0342.ad756c",
"type": "comment",
"name": "format/create log",
"info": "",
"x": 1040,
"y": 260,
"wires": []
"id": "eb6371f4.6c077",
"type": "comment",
"name": "archive when too big",
"info": "",
"x": 1130,
"y": 340,
"wires": []
"id": "90358433.c12f58",
"type": "comment",
"name": "maintain 15 log archive",
"info": "",
"x": 940,
"y": 420,
"wires": []
"id": "907fadd6.c24b8",
"type": "change",
"name": "Format CSV delim (||) ",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "msg.level & '||' & msg.type & '||' & msg.id & '||' & msg.name & '||' & msg.time & '||' & msg.msg\t",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 440,
"y": 260,
"wires": [
"5989b2b4.2dacec"
"id": "5989b2b4.2dacec",
"type": "string",
"name": "Decode Html",
"methods": [
"name": "decodeHTMLEntities",
"params": []
"prop": "payload",
"propout": "payload",
"object": "msg",
"objectout": "msg",
"x": 630,
"y": 260,
"wires": [
"9c740a.039f3bf8"
"id": "53189136.8abce",
"type": "debug",
"name": "",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"x": 400,
"y": 200,
"wires": []
"id": "c0527395.c6582",
"type": "websocket in",
"name": "HE Logs Socket",
"server": "",
"client": "b2f3490e.fc20e8",
"x": 240,
"y": 260,
"wires": [
"907fadd6.c24b8",
"53189136.8abce"
"id": "b2f3490e.fc20e8",
"type": "websocket-client",
"z": "",
"path": "ws://192.168.1.111/logsocket",
"tls": "",
"wholemsg": "true"
This is great, thanks! Turning the csv into an excel spreadsheet that looks good is probably something I can fumble through. But with the Node red stuff I’m pretty clueless so thanks again!!
This is a snippet of what the output log file looks like:
I then import this into excel and use "||" as the custom delimiter:
Once loaded on the spreadsheet, ytou should end up with a page that looks like this:
I set up the spreadsheet to refresh the data when the file is opened.
I also do some formatting, sorting, quick access to archived logs and other customizations using the Power Query Editor but those steps are a bit too detailed to share here...and more for my personal use case. PM me if you are familiar with the Power Query editor and want to dive a bit deeper.
So I've imported the node red flow. I added "node-red-contrib-fs-ops" to try to get it to work. Was that correct? I think the output into the log file doesn't look right in some cases. It seems like some things are being cut off.
info||dev||1164||Living Room Window 2||2019-11-03 08:39:17.999||Living Room Window 2 temperature is 62.97°F
info||app||1771||Living Room Recessed Lights - off only||2019-11-03 08:39:30.358||Motion inactive Living Room Motion Sensoinfo|info||app||1709||Study Lights - Occupancy||2019-11-03 08:39:30.392||Not turning off: disabled by Living Roominfo||app||1771||Living Room Reinfo||dev||586||Kitchen Motion Sensor||2019-11-03 08:39:31.345||Kitchen Motion Sensor is 33%RH
gyDuration is 96.55 Days
info||dev||1483||Outdoor Motion Sensor||2019-11-03 08:39:37.120||Outdoor Motion Sensor illuminance is 2604 Lux
info||app||1587||Living Room Fan<span style='color:red'> (paused)</span>||2019-11-03 08:39:39.523||Motion on info||app||1709||Study Lights - Occupancy||2019-11-03 info||app||1771||Living Room Recessed Lights - off only||2019-11-03 08:39:39.5info||app||1588||Study Fan<span style='color:retrace||app||743||Morning Wake Up Motion Zone Controller||2019-11-03 08:39:39.564||Qualifying triggers were notinfo||app||1info||dev||1106||Living Room A/C Power Switch||2019-11-03 08:39:40.204||Living Room A/C Power Switch power iinfo||dev||1483||Outdoor Motion Sensor||2019-11-03 08:39:47.062||Outdoor Motion Sensor illuminance is 2599 Lux
info||app||1771||Living Room Recessed Lights - off only||2019-11-03 08:39:51.228||Motion inactive Living Room Moinfo||app||1709info||app||1709||Study Lights - Occupancy||2019-11-03 08:39:51.257||Not turning off: disabled by Linfo||app||1771||Living Room Recessed Liginfo||app||1771||Living Room Recessed Lights - off only||2019-11-03 08:39:54.335||Motion inactive Living Room Minfo||app||1709|info||app||1709||Study Lights - Occupancy||2019-11-03 08:39:54.359||Not turning off: disabled by info||app||1771||Living Room Recessed Lighinfo||app||1709||Study Lights - Occupancy||2019-11-03 08:39:58.031||Motion on additional motion sensor Livinginfo||app||1588||Study info||app||1587||Living Room Fan<span style='color:red'> (paused)</span>||2019-11-03 08:39:58.050||Motion on additional motion sensor info||app||1771||Living Room trace||app||743||Morning Wake Up Motion Zone Controller||2019-11-03 08:39:58.052||Qualifying triinfo||app||1771||Living Roinfo||dev||1483||Outdoor Motion Sensor||2019-11-03 08:40:02.051||Outdoor Motion Sensor illumininfo||dev||618||Boys’ Room Temp/Humidity Sensor||2019-11-03 08:40:06.060||Boys’ Room Temp/Humidity Sensor: humidity is 35%
.6°F
Can you open the log file in Notepad (fullscreen) and take a screenshot? I can't quite read the info above.
sorry about that. will pm you to try to figure it out. Thanks again.
You might check out advance-logger node, it should be able to replace the lower two rows of nodes in your flow there all doing log rotation etc.
I did but it wouldn't cooperate with my specific use case.
has anyone used the new post feature of the maker api with Node Red yet?
I have, and it worked perfectly. I only connected a few devices on my dev hub to test the functionality but it performed perfectly with that scenario.
Sooo, out of curiosity, has anyone tried this yet? The rabbit hole just turned into a sinkhole!
I just hooked it up and WOW!!! The amount of things you can do is mind boggling.
Do you mind sharing your flow? Specifically the Influxdb portion.
