Last event I had was 630am - left the house at 8am and typically would of got a push that I left the geo-fence. Any way to stop these hub lockups ?
[app:322](http://192.168.1.140/logs/past#app322)2019-08-03 12:19:22.533 pm [error](http://192.168.1.140/installedapp/configure/322)java.sql.SQLException: Connections could not be acquired from the underlying database! (updateMembers)
[dev:262](http://192.168.1.140/logs/past#dev262)2019-08-03 12:19:22.495 pm [error](http://192.168.1.140/device/edit/262)java.sql.SQLException: Connections could not be acquired from the underlying database! on line 333 (generatePresenceEvent)
[dev:262](http://192.168.1.140/logs/past#dev262)2019-08-03 12:19:22.470 pm [error](http://192.168.1.140/device/edit/262)java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 110 (extraInfo)
[dev:261](http://192.168.1.140/logs/past#dev261)2019-08-03 12:19:22.346 pm [error](http://192.168.1.140/device/edit/261)java.sql.SQLException: An SQLException was provoked by the following failure: com.mchange.v2.resourcepool.ResourcePoolException: A ResourcePool cannot acquire a new resource -- the factory or source appears to be down. on line 370 (generatePresenceEvent)
