Hi, I realized a few weeks ago that Hubitat set the maximum age of device data to 31 days, without any apparent ability to change that value. So I figured I'd make a Rule to write changed data to a .csv file on the hub, and access that as needed. Now I come to find out that Hubitat is arbitrarily deleting or truncating my .csv file, even though there is no delete action in my rule. I happened to find a log entry that shows the Rule Machine at one point tried to delete it and encountered an error. I want Rule Machine to NOT randomly delete my file whenever it feels like it. This seems like something that needs to be fixed. Here is my Rule and log entry I found from earlier today; I have not changed this rule in several weeks:
To do the Append I believe RM reads the file into memory, adds the new data to the memory copy, deletes the old file and then writes a new file with the same name from the data in memory.
Not quite. It does read the file into memory, then writes the file back with the appended string. Not a new file, and no deletion.
There is a way, but you should use extreme caution when changing things like this. This number was set a certain way to manage hub free memory, and how many read/writes you make to the memory card. You could introduce unintended consequences by changing things, I am not endorsing doing this, but the info is out there on the forum.
That said, the linked thread below should have the settings you want. In particular, I think you are wanting max Event Age Days?
Possible slow down problem with 2.3.0.124? - #108 by tony.fleisher
Yes that is exactly what I needed, thanks! I set the global max age of 365 and then set low event count limits on all but the sensors I need long history for.
Well, you just did what I warned you not to, good luck!
you could feed into nodered and keep the data as long as you'd like, and avoid a possible hub slowdown
Or anything else. InfluxDB, with visualization using Grafana, is a popular choice:
These are all very helpful, thank you. For now I will wait and see what effect this has on the hub, if any. I have only a small number of sensors from which I am wanting long-term data. It is difficult for me to imagine how the age of the data matters any more than its quantity or capture rate.
