Lot of thanks, I use it open and close the have directly... I hope it doesn't fail. Opening and closing every gay many times
I've bought 4 with ZigBee but the hub doesn't see them at all, could someone please advise if there's something I can do to make it work?
can you post a link to the product page?, as a start I can look to see what if any Zigbee certifications the device has.
No certification on the Zigbee website (if that's the right place to look)
https://zigbeealliance.org/zigbee_products/?product_type=certified_product&se=Eurotronic
interesting, doesn't appear that the alliance certified it, however having a look at the product manual it appears to to follow spec in regards to what would normally be part of a thermostat function.
So by all accounts that I see it should be possible to make it work.
Did the device even join?, what happened when you went attempted to include it?
I don't see it in the "Add devices" -> "Zigbee" at all. Was wondering if changing a channel from default 20 would help?
ok, do you have other zigbee devices installed?, if so what devices?
Currently only 4x "Innr Smart Plug" - Innr SmartPlug, Philips Hue* & Echo Plus: Amazon.de: Elektronik
Can I ask what platform you are coming from?.. Because if you have these devices working in say smartthings... It is pretty trivial to port the drviers..
The only "smart" thing I've used before was Xiaomi (gateway, ceiling light, led strip, outlet, water sensor, motion sensor, door open sensor).
The devicec I've mentioned are all brand new, straight out of the box.
I can't be sure, but I don't think these are routers, so you might just have a mesh issue.
Zigbee thermostats have very few differences between each other at a fundamental level.
My bet is that if you got the device to join, it would probably work with one of the existing zigbee thermostat drivers that we have.
I might unplug all the other zigbee devices you have, take one of these thermostat heads near the hub (within one to 2 meters) and try joining it...
Judging by the output from "/hub/zigbee/getChildAndRouteInfo" they are:
Route Table Entry
status:Active, age:64, routeRecordState:0, concentratorType:None, [Outlet - LivingRoom - Projector, 1768] via [Outlet - LivingRoom - Projector, 1768]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Outlet - Kitchen - Kettle, 0819] via [Outlet - LivingRoom - Projector, 1768]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Outlet - LivingRoom - Vacuum, 7AA5] via [Outlet - LivingRoom - Projector, 1768]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Outlet - Bedroom - Heater, 487C] via [Outlet - LivingRoom - Projector, 1768]
I was always keeping the TRV right near the hub, will try to move it 1m away.
yup, try unplugging the lot of them anyway, i know it doesn't make sense, but we don't have much experience with these plugs, and at least that will eliminate them from the mix, gotta start someplace.
Your only other option is to send me one of these, and I can see whats up with it...
Unplugged all Innr Outlets - still no luck. HE doesn't see them at all
I think I'll just send them back for a full refund if we won't be able to make them connect.
An odd thing that I see in the "Zigbee Log":
0000 2020-02-12 21:56:01.556 profileId:0x0, clusterId:0x8032, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:0
Would this be of any help? It doesn't appear to be triggered by the TRV's though
can you post a screen shot of live logs?, click the past history button
Couldn't make a screenshot that captures all log entries, sorry. Hope the text will be fine.
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:31:20.951 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 66W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:30:54.956 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 65W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:29:12.961 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 66W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:28:31.969 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 65W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:26:46.960 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 66W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:26:33.963 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 65W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:20:55.936 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 66W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:20:39.958 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 65W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:19:25.949 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 66W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:19:10.954 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 65W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:15:45.947 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 66W
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 22:14:56.178 [info](http://10.9.6.67/device/edit/33)Outlet - LivingRoom - PS4 was turned on
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 22:14:54.282 [info](http://10.9.6.67/device/edit/33)Outlet - LivingRoom - PS4 power is 0W
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 22:14:53.716 [info](http://10.9.6.67/device/edit/33)Outlet - LivingRoom - PS4 was turned off
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 22:14:52.608 [warn](http://10.9.6.67/device/edit/33)configure...
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:14:26.935 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 65W
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 22:14:08.990 [info](http://10.9.6.67/device/edit/38)Outlet - LivingRoom - PC power is 0W
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 22:14:00.964 [info](http://10.9.6.67/device/edit/38)Outlet - LivingRoom - PC power is 4W
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 22:13:59.964 [info](http://10.9.6.67/device/edit/38)Outlet - LivingRoom - PC power is 1W
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 22:13:47.987 [info](http://10.9.6.67/device/edit/38)Outlet - LivingRoom - PC was turned on
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 22:13:45.132 [info](http://10.9.6.67/device/edit/38)Outlet - LivingRoom - PC power is 0W
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 22:13:44.551 [info](http://10.9.6.67/device/edit/38)Outlet - LivingRoom - PC was turned off
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 22:13:43.097 [warn](http://10.9.6.67/device/edit/38)configure...
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:13:37.950 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 66W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:12:49.938 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 65W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:12:22.946 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 66W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:11:01.931 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 65W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:10:55.934 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 63W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:10:51.935 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 62W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:10:50.961 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 60W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:10:49.941 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 59W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:10:48.971 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater power is 52W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:10:43.540 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater is on
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 22:10:41.976 [info](http://10.9.6.67/device/edit/34)Outlet - Bedroom - Heater is on
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 22:03:44.840 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle is on
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 22:03:43.249 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle is on
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 22:03:26.859 [info](http://10.9.6.67/device/edit/37)Outlet - LivingRoom - Projector is on
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 22:03:25.894 [info](http://10.9.6.67/device/edit/37)Outlet - LivingRoom - Projector is on
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:59:20.936 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:59:19.949 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:59:19.320 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:58:19.309 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:57:15.714 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:57:14.699 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:57:14.531 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:56:14.520 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:55:25.537 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:54:47.701 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:54:46.848 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:54:25.526 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:54:22.718 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:53:46.837 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:52:48.180 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:51:48.177 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:46:50.534 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:45:50.522 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:45:48.309 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:44:48.286 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:44:23.730 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:43:23.719 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:32:44.000 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:31:44.180 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:30:05.938 infoIris Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:30:00.903 infoIris Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:30:00.506 infoIris Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:29:07.866 infoIris Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:29:07.770 infoIris Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:29:05.932 infoIris Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:29:03.850 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:29:00.495 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:28:08.754 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:28:07.758 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:28:07.692 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:27:07.678 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:27:05.006 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 21:26:04.993 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 20:18:10.837 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 20:18:09.853 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 20:18:09.613 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 20:17:17.219 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 20:17:16.667 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 20:17:09.605 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 20:17:07.007 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 20:16:16.655 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 20:15:08.752 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 20:14:08.739 infoZigbee Discovery Running
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:12:52.637 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 0W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:12:49.620 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 188W
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 20:12:25.280 [info](http://10.9.6.67/device/edit/36)Outlet - LivingRoom - Vacuum was turned on
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 20:12:22.272 [info](http://10.9.6.67/device/edit/36)Outlet - LivingRoom - Vacuum was turned off
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:12:13.659 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 199W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:12:10.645 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 197W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:12:05.621 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 199W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:11:33.615 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 197W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:11:27.636 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 196W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:11:01.654 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 197W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:10:27.603 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 199W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:10:24.608 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 197W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:10:23.641 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 199W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:10:21.643 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 197W
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 20:10:14.248 [info](http://10.9.6.67/device/edit/36)Socket 5 was turned on
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:10:12.644 [info](http://10.9.6.67/device/edit/35)Outlet - Kitchen - Kettle power is 199W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:09:14.639 [info](http://10.9.6.67/device/edit/35)Socket 4 power is 197W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:08:48.644 [info](http://10.9.6.67/device/edit/35)Socket 4 power is 199W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:08:45.639 [info](http://10.9.6.67/device/edit/35)Socket 4 power is 201W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 20:08:43.634 [info](http://10.9.6.67/device/edit/35)Socket 4 was turned on
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 20:07:51.973 [info](http://10.9.6.67/device/edit/37)Socket 3 was turned on
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 20:06:40.994 [info](http://10.9.6.67/device/edit/34)Socket 2 was turned on
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 19:47:20.871 [warn](http://10.9.6.67/device/edit/38)debug logging disabled...
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 19:47:10.529 [warn](http://10.9.6.67/device/edit/36)debug logging disabled...
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 19:46:58.995 [warn](http://10.9.6.67/device/edit/35)debug logging disabled...
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:46:30.547 [warn](http://10.9.6.67/device/edit/37)debug logging disabled...
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 19:45:57.862 [warn](http://10.9.6.67/device/edit/33)debug logging disabled...
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:45:01.795 [warn](http://10.9.6.67/device/edit/34)debug logging disabled...
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:44:54.968 [debug](http://10.9.6.67/device/edit/34)descMap:[raw:487C010B040A050521E900, dni:487C, endpoint:01, cluster:0B04, size:0A, attrId:0505, encoding:21, command:0A, value:00E9, clusterInt:2820, attrInt:1285]
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:44:12.965 [debug](http://10.9.6.67/device/edit/34)descMap:[raw:487C010B040A050521ED00, dni:487C, endpoint:01, cluster:0B04, size:0A, attrId:0505, encoding:21, command:0A, value:00ED, clusterInt:2820, attrInt:1285]
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 19:40:04.206 [debug](http://10.9.6.67/device/edit/36)descMap:[raw:7AA5010B040A050521E700, dni:7AA5, endpoint:01, cluster:0B04, size:0A, attrId:0505, encoding:21, command:0A, value:00E7, clusterInt:2820, attrInt:1285]
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:39:46.960 [debug](http://10.9.6.67/device/edit/34)descMap:[raw:487C010B040A050521E900, dni:487C, endpoint:01, cluster:0B04, size:0A, attrId:0505, encoding:21, command:0A, value:00E9, clusterInt:2820, attrInt:1285]
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 19:39:22.204 [debug](http://10.9.6.67/device/edit/36)descMap:[raw:7AA5010B040A050521EB00, dni:7AA5, endpoint:01, cluster:0B04, size:0A, attrId:0505, encoding:21, command:0A, value:00EB, clusterInt:2820, attrInt:1285]
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:39:18.970 [debug](http://10.9.6.67/device/edit/34)descMap:[raw:487C010B040A050521ED00, dni:487C, endpoint:01, cluster:0B04, size:0A, attrId:0505, encoding:21, command:0A, value:00ED, clusterInt:2820, attrInt:1285]
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 19:38:26.217 [debug](http://10.9.6.67/device/edit/36)descMap:[raw:7AA5010B040A050521E700, dni:7AA5, endpoint:01, cluster:0B04, size:0A, attrId:0505, encoding:21, command:0A, value:00E7, clusterInt:2820, attrInt:1285]
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 19:37:30.220 [debug](http://10.9.6.67/device/edit/36)descMap:[raw:7AA5010B040A050521EB00, dni:7AA5, endpoint:01, cluster:0B04, size:0A, attrId:0505, encoding:21, command:0A, value:00EB, clusterInt:2820, attrInt:1285]
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 19:17:20.807 [warn](http://10.9.6.67/device/edit/38)configure...
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 19:17:12.057 [info](http://10.9.6.67/device/edit/36)Socket 5 power is 0W
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 19:17:12.046 [debug](http://10.9.6.67/device/edit/36)descMap:[raw:7AA5010B040C0B05290000, dni:7AA5, endpoint:01, cluster:0B04, size:0C, attrId:050B, encoding:29, command:01, value:0000, clusterInt:2820, attrInt:1291]
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 19:17:11.445 [info](http://10.9.6.67/device/edit/36)Socket 5 was turned off
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 19:17:11.428 [debug](http://10.9.6.67/device/edit/36)descMap:[raw:7AA50100060A00001000, dni:7AA5, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 19:17:10.460 [warn](http://10.9.6.67/device/edit/36)configure...
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 19:17:00.556 [info](http://10.9.6.67/device/edit/35)Socket 4 power is 0W
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 19:17:00.546 [debug](http://10.9.6.67/device/edit/35)descMap:[raw:0819010B040C0B05290000, dni:0819, endpoint:01, cluster:0B04, size:0C, attrId:050B, encoding:29, command:01, value:0000, clusterInt:2820, attrInt:1291]
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 19:16:59.957 [info](http://10.9.6.67/device/edit/35)Socket 4 was turned off
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 19:16:59.942 [debug](http://10.9.6.67/device/edit/35)descMap:[raw:08190100060A00001000, dni:0819, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 19:16:58.935 [warn](http://10.9.6.67/device/edit/35)configure...
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:16:32.064 [info](http://10.9.6.67/device/edit/37)Socket 3 power is 0W
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:16:32.053 [debug](http://10.9.6.67/device/edit/37)descMap:[raw:1768010B040C0B05290000, dni:1768, endpoint:01, cluster:0B04, size:0C, attrId:050B, encoding:29, command:01, value:0000, clusterInt:2820, attrInt:1291]
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:16:31.427 [info](http://10.9.6.67/device/edit/37)Socket 3 is off
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:16:31.412 [debug](http://10.9.6.67/device/edit/37)descMap:[raw:17680100060A00001000, dni:1768, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:16:30.457 [warn](http://10.9.6.67/device/edit/37)configure...
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:16:26.598 [warn](http://10.9.6.67/device/edit/37)description logging is: true
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:16:26.596 [warn](http://10.9.6.67/device/edit/37)debug logging is: true
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:16:26.595 [warn](http://10.9.6.67/device/edit/37)power reporting is: true
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:16:26.592 [info](http://10.9.6.67/device/edit/37)updated...
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 19:15:57.801 [warn](http://10.9.6.67/device/edit/33)configure...
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 19:15:31.471 [warn](http://10.9.6.67/device/edit/33)configure...
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 19:15:21.749 [warn](http://10.9.6.67/device/edit/33)description logging is: true
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 19:15:21.748 [warn](http://10.9.6.67/device/edit/33)debug logging is: true
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 19:15:21.746 [warn](http://10.9.6.67/device/edit/33)power reporting is: true
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 19:15:21.744 [info](http://10.9.6.67/device/edit/33)updated...
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:15:03.282 [info](http://10.9.6.67/device/edit/34)Socket 2 power is 0W
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:15:03.269 [debug](http://10.9.6.67/device/edit/34)descMap:[raw:487C010B040C0B05290000, dni:487C, endpoint:01, cluster:0B04, size:0C, attrId:050B, encoding:29, command:01, value:0000, clusterInt:2820, attrInt:1291]
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:15:02.634 [info](http://10.9.6.67/device/edit/34)Socket 2 was turned off
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:15:02.618 [debug](http://10.9.6.67/device/edit/34)descMap:[raw:487C0100060A00001000, dni:487C, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:15:01.658 [warn](http://10.9.6.67/device/edit/34)configure...
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:14:57.745 [warn](http://10.9.6.67/device/edit/34)description logging is: true
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:14:57.744 [warn](http://10.9.6.67/device/edit/34)debug logging is: true
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:14:57.742 [warn](http://10.9.6.67/device/edit/34)power reporting is: true
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:14:57.740 [info](http://10.9.6.67/device/edit/34)updated...
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:14:34.882 [warn](http://10.9.6.67/device/edit/37)configure...
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 19:13:29.698 [warn](http://10.9.6.67/device/edit/38)configure...
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 19:13:23.292 [warn](http://10.9.6.67/device/edit/38)description logging is: true
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 19:13:23.290 [warn](http://10.9.6.67/device/edit/38)debug logging is: true
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 19:13:23.288 [warn](http://10.9.6.67/device/edit/38)power reporting is: true
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 19:13:23.287 [info](http://10.9.6.67/device/edit/38)updated...
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:10:09.760 [info](http://10.9.6.67/device/edit/34)Zigbee parsed:[raw:catchall: 0000 0006 00 00 0040 00 487C 00 00 0000 00 00 66FDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:487C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[66, FD, FF, 04, 01, 01, 19, 00, 00]]
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 19:09:39.342 [info](http://10.9.6.67/device/edit/34)Zigbee parsed:[raw:catchall: 0000 0013 00 00 0040 00 487C 00 00 0000 00 00 657C489C148903008D15008E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:487C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[65, 7C, 48, 9C, 14, 89, 03, 00, 8D, 15, 00, 8E]]
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:09:05.751 [info](http://10.9.6.67/device/edit/37)Zigbee parsed:[raw:catchall: 0000 0006 00 00 0040 00 1768 00 00 0000 00 00 CEFDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:1768, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[CE, FD, FF, 04, 01, 01, 19, 00, 00]]
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:08:35.344 [info](http://10.9.6.67/device/edit/37)Zigbee parsed:[raw:catchall: 0000 0013 00 00 0040 00 1768 00 00 0000 00 00 CD681780E68803008D15008E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:1768, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[CD, 68, 17, 80, E6, 88, 03, 00, 8D, 15, 00, 8E]]
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 19:07:57.421 [info](http://10.9.6.67/device/edit/38)Zigbee parsed:[raw:catchall: 0000 0013 00 00 0040 00 A9CE 00 00 0000 00 00 77CEA942618803008D15008E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:A9CE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[77, CE, A9, 42, 61, 88, 03, 00, 8D, 15, 00, 8E]]
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 19:07:57.417 [info](http://10.9.6.67/device/edit/37)Zigbee parsed:[raw:catchall: 0000 0013 00 00 0040 00 1768 00 00 0000 00 00 04681780E68803008D15008E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:1768, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[04, 68, 17, 80, E6, 88, 03, 00, 8D, 15, 00, 8E]]
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:53:29.401 [warn](http://10.9.6.67/device/edit/36)configure...
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:53:26.870 [warn](http://10.9.6.67/device/edit/36)description logging is: true
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:53:26.868 [warn](http://10.9.6.67/device/edit/36)debug logging is: true
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:53:26.858 [warn](http://10.9.6.67/device/edit/36)power reporting is: true
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:53:26.856 [info](http://10.9.6.67/device/edit/36)updated...
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:52:57.851 [warn](http://10.9.6.67/device/edit/35)configure...
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:52:44.711 [warn](http://10.9.6.67/device/edit/35)description logging is: true
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:52:44.710 [warn](http://10.9.6.67/device/edit/35)debug logging is: true
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:52:44.708 [warn](http://10.9.6.67/device/edit/35)power reporting is: true
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:52:44.702 [info](http://10.9.6.67/device/edit/35)updated...
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:52:00.479 infoZigbee Discovery Stopped
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 18:51:28.000 [info](http://10.9.6.67/device/edit/38)Zigbee parsed:[raw:catchall: 0000 0006 00 00 0040 00 A9CE 00 00 0000 00 00 9EFDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:A9CE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[9E, FD, FF, 04, 01, 01, 19, 00, 00]]
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:51:00.467 infoZigbee Discovery Running
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 18:50:59.921 [info](http://10.9.6.67/device/edit/38)fingerprint profileId:"C05E", endpointId:"01", inClusters:"0000,0004,0003,0006,0008,0005,0B04,0702,000A", outClusters:"0003,0019,000A", model:"SP 120", manufacturer:"innr"
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 18:50:59.834 [trace](http://10.9.6.67/device/edit/38)ZCL version:02
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 18:50:59.825 [trace](http://10.9.6.67/device/edit/38)Software Build Id:2.0
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 18:50:59.823 [trace](http://10.9.6.67/device/edit/38)Model:SP 120
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 18:50:59.818 [trace](http://10.9.6.67/device/edit/38)Manufacturer:innr
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 18:50:59.723 [debug](http://10.9.6.67/device/edit/38)getting info for unknown Zigbee device...
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:50:58.279 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:50:57.700 infoCreated Unknown Zigbee Device
[dev:38](http://10.9.6.67/logs/past#dev38)2020-02-12 18:50:57.661 [debug](http://10.9.6.67/device/edit/38)configure() called...
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:50:57.087 infoInitializing Zigbee Device 00158D0003886142, A9CE
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 18:50:34.682 [info](http://10.9.6.67/device/edit/37)fingerprint profileId:"C05E", endpointId:"01", inClusters:"0000,0004,0003,0006,0008,0005,0B04,0702,000A", outClusters:"0003,0019,000A", model:"SP 120", manufacturer:"innr"
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 18:50:34.598 [trace](http://10.9.6.67/device/edit/37)ZCL version:02
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 18:50:34.590 [trace](http://10.9.6.67/device/edit/37)Software Build Id:2.0
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 18:50:34.588 [trace](http://10.9.6.67/device/edit/37)Model:SP 120
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 18:50:34.583 [trace](http://10.9.6.67/device/edit/37)Manufacturer:innr
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 18:50:34.485 [debug](http://10.9.6.67/device/edit/37)getting info for unknown Zigbee device...
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 18:50:33.614 [info](http://10.9.6.67/device/edit/37)Zigbee parsed:[raw:catchall: 0000 8005 00 00 0040 00 1768 00 00 0000 00 00 2F006817020102, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:1768, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2F, 00, 68, 17, 02, 01, 02]]
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:50:32.477 infoCreated Unknown Zigbee Device
[dev:37](http://10.9.6.67/logs/past#dev37)2020-02-12 18:50:32.439 [debug](http://10.9.6.67/device/edit/37)configure() called...
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:50:30.389 infoInitializing Zigbee Device 00158D000388E680, 1768
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:49:58.273 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:49:34.355 infoZigbee Discovery Stopped
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:29.633 [info](http://10.9.6.67/device/edit/35)fingerprint profileId:"C05E", endpointId:"01", inClusters:"0000,0004,0003,0006,0008,0005,0B04,0702,000A", outClusters:"0003,0019,000A", model:"SP 120", manufacturer:"innr"
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:29.555 [trace](http://10.9.6.67/device/edit/35)ZCL version:02
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:29.548 [trace](http://10.9.6.67/device/edit/35)Software Build Id:2.0
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:29.546 [trace](http://10.9.6.67/device/edit/35)Model:SP 120
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:29.541 [trace](http://10.9.6.67/device/edit/35)Manufacturer:innr
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:29.455 [debug](http://10.9.6.67/device/edit/35)getting info for unknown Zigbee device...
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:27.385 [debug](http://10.9.6.67/device/edit/35)configure() called...
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:16.379 [info](http://10.9.6.67/device/edit/35)fingerprint profileId:"C05E", endpointId:"01", inClusters:"0000,0004,0003,0006,0008,0005,0B04,0702,000A", outClusters:"0003,0019,000A", model:"SP 120", manufacturer:"innr"
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:16.287 [trace](http://10.9.6.67/device/edit/35)ZCL version:02
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:16.273 [trace](http://10.9.6.67/device/edit/35)Software Build Id:2.0
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:16.271 [trace](http://10.9.6.67/device/edit/35)Model:SP 120
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:16.266 [trace](http://10.9.6.67/device/edit/35)Manufacturer:innr
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:16.171 [debug](http://10.9.6.67/device/edit/35)getting info for unknown Zigbee device...
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:14.174 [info](http://10.9.6.67/device/edit/35)Zigbee parsed:[raw:catchall: 0000 0013 00 00 0040 00 0819 00 00 0000 00 00 671908C8EE8803008D15008E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:0819, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[67, 19, 08, C8, EE, 88, 03, 00, 8D, 15, 00, 8E]]
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:49:14.114 infoFound Previously Joined Zigbee Device Device
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:14.082 [debug](http://10.9.6.67/device/edit/35)configure() called...
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:49:01.950 [info](http://10.9.6.67/device/edit/36)Zigbee parsed:[raw:catchall: 0000 0006 00 00 0040 00 7AA5 00 00 0000 00 00 7EFDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7AA5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[7E, FD, FF, 04, 01, 01, 19, 00, 00]]
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:49:00.950 [info](http://10.9.6.67/device/edit/35)Zigbee parsed:[raw:catchall: 0000 0006 00 00 0040 00 E7A1 00 00 0000 00 00 98FDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:E7A1, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[98, FD, FF, 04, 01, 01, 19, 00, 00]]
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:48:35.903 [info](http://10.9.6.67/device/edit/36)fingerprint profileId:"C05E", endpointId:"01", inClusters:"0000,0004,0003,0006,0008,0005,0B04,0702,000A", outClusters:"0003,0019,000A", model:"SP 120", manufacturer:"innr"
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:48:35.817 [trace](http://10.9.6.67/device/edit/36)ZCL version:02
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:48:35.810 [trace](http://10.9.6.67/device/edit/36)Software Build Id:2.0
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:48:35.805 [trace](http://10.9.6.67/device/edit/36)Model:SP 120
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:48:35.799 [trace](http://10.9.6.67/device/edit/36)Manufacturer:innr
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:48:35.699 [debug](http://10.9.6.67/device/edit/36)getting info for unknown Zigbee device...
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:48:34.735 [info](http://10.9.6.67/device/edit/36)Zigbee parsed:[raw:catchall: 0000 8005 00 00 0040 00 7AA5 00 00 0000 00 00 1D00A57A020102, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7AA5, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[1D, 00, A5, 7A, 02, 01, 02]]
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:48:34.345 infoZigbee Discovery Running
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:48:33.896 [info](http://10.9.6.67/device/edit/35)fingerprint profileId:"C05E", endpointId:"01", inClusters:"0000,0004,0003,0006,0008,0005,0B04,0702,000A", outClusters:"0003,0019,000A", model:"SP 120", manufacturer:"innr"
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:48:33.768 [trace](http://10.9.6.67/device/edit/35)ZCL version:02
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:48:33.751 [trace](http://10.9.6.67/device/edit/35)Software Build Id:2.0
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:48:33.748 [trace](http://10.9.6.67/device/edit/35)Model:SP 120
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:48:33.718 [trace](http://10.9.6.67/device/edit/35)Manufacturer:innr
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:48:33.704 infoCreated Unknown Zigbee Device
[dev:36](http://10.9.6.67/logs/past#dev36)2020-02-12 18:48:33.619 [debug](http://10.9.6.67/device/edit/36)configure() called...
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:48:33.503 [debug](http://10.9.6.67/device/edit/35)getting info for unknown Zigbee device...
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:48:32.218 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:48:31.458 infoInitializing Zigbee Device 00158D0003893D14, 7AA5
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:48:31.408 infoCreated Unknown Zigbee Device
[dev:35](http://10.9.6.67/logs/past#dev35)2020-02-12 18:48:31.358 [debug](http://10.9.6.67/device/edit/35)configure() called...
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:48:30.665 infoInitializing Zigbee Device 00158D000388EEC8, E7A1
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 18:47:36.839 [info](http://10.9.6.67/device/edit/34)fingerprint profileId:"C05E", endpointId:"01", inClusters:"0000,0004,0003,0006,0008,0005,0B04,0702,000A", outClusters:"0003,0019,000A", model:"SP 120", manufacturer:"innr"
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 18:47:36.754 [trace](http://10.9.6.67/device/edit/34)ZCL version:02
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 18:47:36.745 [trace](http://10.9.6.67/device/edit/34)Software Build Id:2.0
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 18:47:36.742 [trace](http://10.9.6.67/device/edit/34)Model:SP 120
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 18:47:36.737 [trace](http://10.9.6.67/device/edit/34)Manufacturer:innr
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 18:47:36.623 [debug](http://10.9.6.67/device/edit/34)getting info for unknown Zigbee device...
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:47:34.588 infoCreated Unknown Zigbee Device
[dev:34](http://10.9.6.67/logs/past#dev34)2020-02-12 18:47:34.546 [debug](http://10.9.6.67/device/edit/34)configure() called...
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:47:33.854 infoInitializing Zigbee Device 00158D000389149C, 487C
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:47:32.212 infoZigbee Discovery Running
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 18:47:30.907 [info](http://10.9.6.67/device/edit/33)Zigbee parsed:[raw:catchall: 0000 0013 00 00 0040 00 D587 00 00 0000 00 00 4B87D5024C8803008D15008E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D587, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[4B, 87, D5, 02, 4C, 88, 03, 00, 8D, 15, 00, 8E]]
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:44:14.630 infoZigbee Discovery Stopped
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 18:43:46.785 [info](http://10.9.6.67/device/edit/33)Zigbee parsed:[raw:catchall: 0000 0006 00 00 0040 00 D587 00 00 0000 00 00 6FFDFF040101190000, profileId:0000, clusterId:0006, clusterInt:6, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:D587, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[6F, FD, FF, 04, 01, 01, 19, 00, 00]]
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 18:43:21.243 [info](http://10.9.6.67/device/edit/33)fingerprint profileId:"C05E", endpointId:"01", inClusters:"0000,0004,0003,0006,0008,0005,0B04,0702,000A", outClusters:"0003,0019,000A", model:"SP 120", manufacturer:"innr"
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 18:43:21.150 [trace](http://10.9.6.67/device/edit/33)ZCL version:02
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 18:43:21.142 [trace](http://10.9.6.67/device/edit/33)Software Build Id:2.0
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 18:43:21.140 [trace](http://10.9.6.67/device/edit/33)Model:SP 120
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 18:43:21.134 [trace](http://10.9.6.67/device/edit/33)Manufacturer:innr
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 18:43:20.967 [debug](http://10.9.6.67/device/edit/33)getting info for unknown Zigbee device...
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 18:43:19.329 [info](http://10.9.6.67/device/edit/33)fingerprint profileId:"C05E", endpointId:"01", inClusters:"0000,0004,0003,0006,0008,0005,0B04,0702,000A", outClusters:"0003,0019,000A", model:"SP 120", manufacturer:"innr"
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:43:19.038 infoCreated Unknown Zigbee Device
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 18:43:18.869 [trace](http://10.9.6.67/device/edit/33)Manufacturer:innr
[dev:33](http://10.9.6.67/logs/past#dev33)2020-02-12 18:43:18.784 [debug](http://10.9.6.67/device/edit/33)configure() called...
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:43:16.098 infoInitializing Zigbee Device 00158D0003884C02, D587
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-12 18:43:14.647 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 19:04:30.503 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 19:03:30.490 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 19:03:28.432 infoZ-Wave Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 19:02:51.444 infoZ-Wave Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 19:02:49.038 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 19:02:28.930 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 19:02:25.356 infoIris Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 19:01:26.191 infoIris Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 18:55:49.734 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 18:55:23.820 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 18:55:22.113 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 18:54:49.721 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 18:54:36.952 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 18:53:36.940 infoZigbee Discovery Running
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 18:51:47.962 infoZigbee Discovery Stopped
[sys:1](http://10.9.6.67/logs/past#sys1)2020-02-11 18:50:47.972 infoZigbee Discovery Running
have you done a factory reset on the thermostat?, before trying the join?
Tried to, but it goes into connect mode immediately. Will google if there's a way to force it into reset tomorrow.
Thank you for your time!
