It might be using rolling RF codes then, if that's the case you won't be able to get that working. I checked their site and it seems they have WiFi integration meaning they must sell a hub addon for it. See here. I'd reach out to them.
Don't bother with addon systems. They are rubbish. Just get reverse cycle. Although they will do the job nothing beats reverse cycle.
@njanda, I have 6 of them, got it during the oomi indiegogo campaign. Works brilliantly with hubitat with aeotec drivers. It is essentially a rebranded aeotec door/window 6 sensor with nfc chip built in.
Battery suppose to last 10 months per charge but I think mine must be degraded now as it last about 2 to 3 months for doors that are regularly used. Hope that helps.
Hi, how do you find konnected so far? Interested to connect this with the current Hills alarm.
I've been using it for the past 6 months, it works great; I found it's more cost-effective if compared to install reverse cycle to each room (I have 4 bedrooms + large living area).
If anyone’s interested....
ZwavePlus outlets (with USB port ) for under $50 on fleaBay.
this uses the aeotec driver ?
That’s what I believe and hope.
I’ll tell you for sure next week after I get back from Thailand. (If they let me in. LOL)
If they do don't forget to buy toilet paper in duty free, you can't buy it anywhere else apparently !!
@stevebott124 - Found this in the manual " add your Plug to your Z-Wave network via Aeotec by Aeon Labs’ Z-Stick or Minimote controller. If you are using other products as your main Z-Wave controller, such as a Z-Wave gateway, please refer to the part of their respective manual that tells you how to add new devices to your network"
I can't tell of the USB is always on or not from the manual though. Colors would be useful in the Museum for remote troubleshooting so may buy a couple to test then use them instead of the tp-links
yeah - so they act the same as the aeons then.
Sweet!
I’ve ordered 2 in “Black”
I've done the same !
Yeah have seen that before and had a laugh. Thanks for the heads up on the sale off to get some more to replace some xiaomi stuff. I've found them to be alot more reliable.
Yeah. The grief that comes from Xiaomi is just not worth it. IMHO
I’ll go pick some up on my way back from getting toilet paper.
Hahaha it's nuts isn't it.
Hey guys,
I'm open to comments as I'm contemplating pulling the "buy" trigger on one of these to see how it performs as a user interface.
With video input (for rear camera when used in a car) it opens up a few ideas....
Thanks, I bought 3 of these today. Now to find a use for them. They do acceleration, temp, open/closed and xyz axis.
What water leak sensors would you recommend? Is the Smartthings water leak sensor the gold standard?
