The dana lock or any single cylinder style lock work on door one as there is only a deadbolt to replace. The screw holes for the face plate would need to be patched.. also you would need a bar handle to push and pull the door.
Door 2 could use something similar as it would replace the cylinder hole, the just add a basic lever handle. Again, the face plate screw holes would need patching
On door 1, If you took the deadbolt off the inside of the door to attach the Danalock, wouldn’t there be no ‘latch’ to secure the door closed !
What am misunderstanding as I’ve got that same setup, a deadbolt style, on my front door ?
If by upgrade you mean the AC system itself I have a Mitsubishi electric ducted system with their WiFi adaptor and have been working on a driver for their MELCloud service. Still a work in progress.
Sadly, I've got a large Mitsi Heavy Industries system that is complex and about 12yrs old. I've been told approx $10k upgrade but that it's not worth it on a 12yr old system that could die at any time or replace with modern equivalent for circa $30k.
will do @pjam73. I didn't get as much time over Christmas as I thought I would, but made some good progress last weekend. I'll try to send you and early version of the code soon to see how your setup is different to mine.
It does look interesting. ZigBee too. Says they do their own dev. Curious to know to what extent. Rebadging vs ground up. I'd support some homegrown players for sure, depending on price/features.
I've just emailed them to see if they are interested in sending some of their products over to Hubitat in the US to gain official support. See what they say.
