You sir are a legend. I've been procrastinating on preordering the Shelly dimmer and you've just sealed the deal for me.
I just wish there were more options with power monitoring.
I just posted in another thread about a 240V powerboard I'm looking at.
Given it's relevance to the Australian contingent here, I was hoping to see if anyone had any solutions around ethernet controlled powerboards in Australia before I spend a LOT of money on this.
Also, for what it's worth, I purchased the below from Bunnings yesterday.
Seems to work OK, but it's cloud based, so not ideal. Has anyone taken a look at trying to integrate this in to HE? I've literally only taken it out of the box and given it a test play with my mobile.
I've been digging around trying to find out more about what's inside them, but there isn't much info.
Happy days, my HE is arriving today! The fun begins
Nice. Are there screws at the back e.g. can you open it up? I assume it has an ESP8266 or 8285 chipset inside meaning it's probably flashable with Tasmota which in turn will work within HE. If you look further up you can see I flashed a Brilliant smart plug the other day so if it's similar to that it's do-able.
Also Kmart have something similar too.
Excellent that last picture shows that its running an ESP8285 chipset so you can follow my Brilliant guide to flash that. Once it's running Tasmota you'd need to work out the configuration first then in HE you should be able to edit the HE driver in my guide to accommodate the extra switches given it has more than 1.
I might have to look into this.
Look at the tickets on himself folks. Gosh lol. ![]()
bahaha.. I was going to say "non puns intended" LOL
Looks daunting. Not sure I have a sufficiently steady hand to solder that small!
The FTDI adapter in your link apparently will take up to 6 weeks to get to sunny old Melbourne, so I might try and see if there's somewhere local to buy them (I'm sure I will end up paying more than the $3 though)
Yeah can't say I'm super keen to get into pulling apart and soldering stuff. I like to tinker, but soldering does my head in. I imagine if you get into Arduino stuff you'd get pretty comfortable with it.
I just put the thing back together, and am trying to reset the thing, and it's just having none of it, and turning itself off when it's trying to hook up to the network again.
Interestingly, when I initially set it up it had a weird on/off/on moment the first time I fired it up, but it seemed to settle down.
The unit I have seems to have a few marks on it - maybe somebody already had problems with it and returned it? I might go back and swap it out for another one, or use this one as the sacrificial one to update the firmware on - not sure if that is starting behind the 8-ball given it's not working properly already.
You might find a similar one at Jaycar but honestly I haven't looked.
Weird mate. I'd keep an eye on it as it could just be a faulty one. I would make sure it's stable and running properly though before i bothered to flash it etc.
Another smart plug to choose from.
"Instant control via Bluetooth"
Computer says Naaaaaaaaah. Still using ZLL as well, so won't go direct to HE.
They call me "Sir Legend" -- If anyone has seen Sidney Poitier movies you will get it. ![]()
Is there a open API for it ? If so I could possibly bang out some code for it.
BTW I can bang out code for WIFI that has a open API. It's pretty easy to do compared to zigbee/zwave and it will stay local as usual.
I don't think there is, but given that the plan looks like we're going to update the firmware with Tasmota stuff, then probably the point if going to be moot.
