Ok seems custom command in rule machine allows deletion and creation of codes in lock code manager. So can remove or add certain slots/users based on time of day, day of week or a toogle switch on a dashboard. Not quite pausing, but will do what I want unless the sync between lock code manager and the locks isn't reliable doing it frequently.. Time will tell I guess.
Hi, can I know the security keypad that you use because I'm actually looking for one. Will also combine it with yale lock and any to use it to arm/disarm security mode in hubitat. Thanks
What did you offer?
I've ordered one too, for the laundry door.
Has anyone got a good solution for syncing multiple locks? At the moment I've got two schlage locks on the garage and front doors that I try to keep in sync using rule machine. Sometimes they get into a loop though, and just keep locking and unlocking until they eventually sync up again. I've tried changing the delay between change locking/unlocking, but it still seems to malfunction sometimes, due to the delay in reporting state changes.
I'm using the Switch Binding app by @joelwetzel to sync some "dummy" two-way light switches, which had the same feedback loop problem in rule machine, but that can't do locks.
I sync them to home / away states rather than letting them auto lock after set periods etc. rule machine makes this easy.
OK. That isn't quite what I was after. I wanted to make them both lock if I physically or remotely lock one of them, whether we are home or not. Perhaps I need to make another variable that gets updated in Rule machine. Just seems overly complicated for a basic task, so I wondered if anyone had a better solution.
Oh in that case a simple RM rule will do it eg:
Triggers:
Door Lock 1 =Locked
Door Lock 2 =Locked
Logic:
IF "Door Lock 1" = Locked AND "Door Lock 2" = Unlocked
THEN Lock "Door Lock 2"
ELSE IF "Door Lock 2" = Locked AND "Door Lock 1" = Unlocked
THEN Lock "Door Lock 1"
END IF
You might want to add some additional conditions/restrictions, but the logic is simple.
EDIT: I made a couple of quick tweaks, this will only trigger when you lock one of the 2 doors. If you unlock either of them, it wont trigger and lock you out
Yep, that's what I'm using at the moment, but it gets into a loop of locking and unlocking, as the timing between locking and reporting being locked can vary a bit. I've got a 5 second delay, which helped a bit but sometimes it still goes a bit crazy.
I had exactly the same problem with some light switches, but that was solved by using the switch binding app. I was just wondering if there was an equivalent for locks.
If the triggers are only "Locked", it should never fire the rule when doors are "unlocked".
Yeah, but there is also one for "Unlocked", so they get into a feedback loop. I'll try adding the additional conditions and see if that sorts it out.
I made the dude an offer last night. He counteroffered dropping $1 from his listed price. Today he drops the price on the item $5. Twat.
Yeh my problem was shipping was 19 dollars each item.. But he accepted 115 each. He ignored 110. But it still cost 238 shipped because of the rip of charging shipping twice at 19 dollars each.. However they came quickly and had much better feexba k than the others. Seems people got theirs ok from the other sellers.. However one of the other sellers had reports of selling refurbished items. Then claimed it was an accident = wtf
So I first set the master code. Then paired the lock by going into settings in the lock to enable network connect. Paired in hubitat. Can unlock and lock from hubitat..
Sent into lock code manager and set two users with a 4 digit code. Both say enabled.. But the lock doesn't unlock with those codes after typing the codes then pressing hash.
Are the codes not loaded into the lock? Am I doing something wrong?
Go into the lock device and click “get codes” or “configure” (I can’t recall which).
I tried these both. I'll try again though.
Do you see the codes under “current status” showing the codes listed under “lockCodes”?
PS might be worth setting the Max code length too. I did this before configuring the codes.
Yes I see the codes. If I set them in lock manager. Or if I send through the device page. I tried configure, get codes, and refresh.
I have now set the code length, deleted each slot so no codes are in the lock codes. Then added them again and they show there. But the lock does that wave type pattern on the screen which seems to indicate invalid code.
I feel like such a.....
I was pressing # at the end like most codes... But I needed to push * Woops. That was silly. Working fine
lol, I made the same mistake but had forgotten about it!
It's now all working reliably. Just gotta get me head around how much work to create a desktop tile that I can define days and the time a guest code turns on (setcode) plus a toggle/switch to have it on and off.. All involving strings and numbers, variables and connectors.. Perhaps only activated when we've left home...
Maybe leave that for the to do list as gotta get my head around it and working out the * mistake did my head in ha ha.
I can activate and deactivate a code based on time and day set in rule machine (no tile yet) so that's a good start.
