Brought 2 of the Zemismart Zigbee 4 gang TOUCH light switches.
With the below User driver they finally worked properly.
Paired with the hub quickly & simply.
Only annoying bit is they are a fair bit lower WIDTH (72mm) than normal Legrand / Clipsal switch plate, so as a retrofit I've had to do touch-up paint and even had to 3D print a wider backplate to cover a tiny bit of missing plaster!
And the rear box takes a fair amount of space so your wall gang box better be tidy!
Cant lean on the 2 wall screws too much because its main backplate is a bit flexible.
The aluminium edge is nicer than some that are available.
Actual touch functionality is clean, not too touchy or otherwise.
Zemismart Zigbee 1/2/3/4 gang light switches
