What is the expected lifetime of the Model C-7 before it is replaced by the Model C-8? WIll the C-8 have improved Kasa integration?
Thank you
Thank you
Hubitat never announces their hardware plans. At the most recent Hubitat Live, it appeared as if a firmware update would bring Matter compatibility to the C-7.
The Kasa integration is actually a community integration from @djgutheinz that is now built into the platform. @djgutheinz is constantly improving his code or updating it to add support for additional devices, so I would suggest you use his Kasa thread to request new features or support for new devices. I've linked to it below:
Thanks for the quick response. I purchased a Hubitat Elevation US Version × 1 in mid 2021 not paying attention that it didn't work with the Kasa world devices until I was ready to start to use it. Can the V1 be upgraded to a firmware version to incorporate Kasa integration. Is there a chart somewhere that shows the differences in devices. I am sure there are more features, however, it would be nice to know what improvements had been added to see if it would benefit a users use of the device.
The latest version of the firmware already includes the built-in Kasa Integration.
On the App page, click the "Add built-in app" button and search for Kasa.
There are only four five models of the hub to date:
All hubs have similar specs, aside from the 700-series Z-Wave radio on the C-7. The C-5 and newer do run a more finely tuned OS that should eliminate some "scheduled reboot" workarounds some C-3/C-4 users put up with (and even probably some early C-5 users before some more work was done). The C-5 and C-7 also added some network options like the ability to connect the hub to your network over Wi-Fi instead of wired (adapter required and not included), though this isn't recommended if wired is possible.
But beyond Z-Wave (and networking) as above, pretty much every other feature is the same between hubs. Your example of the Kasa integration is one--as mentioned above, that was added in a recent hub firmware update, and so far, these updates have always been available for all hub models dating back to the orignal C-3.
EDIT: For those coming back to this post, there is one more model to add:
Think of it this way, if Hubitat move quicker than you expect, it's rare if not impossible a C-7 will not work with a new revision of the hub, based on prior history... So you could either use a C-7 as a second hub, linking it to a C-X via Hub Mesh, or use it as a development hub, and who doesn't need one of those....
Yes any C7 can be updated to current firmware.
Most (if not All) of the "Kasa" branded devices are supported.
TP-Link also makes some other brands/lines of smart devices, which I think for the most part do not work on the Kasa integration.
The Tapo devices I believe are part of that group.
I have updated the top of the Kasa Thread to be more explicit on supported devices.
