Hubitat Elevation integration with RadioRa2
new to the group...
just purchased C8 and was hoping to make this my "last" hub. Out of the gate I'm having issues with integration with Lutron.
I have the Lutron integration app and have made sure that all the ID's are checked for telnet within the Lutron software. Connected to the "Repeater" not the bridge using a static IP and the logs show a telnet connection.
But when I try to control a light or see feedback - Nothing
Welcome to Hubitat!
There are several posts on this community about RadioRa2. You might search to see if they are helpful. Here is one example:
Did you set up the devices within Hubitat as well? You need to do it manually within Hubitat, it does not automatically import devices from the main repeater (like some other systems including Home Assistant does). There are 2 ways in Hubitat - interactive and list. I recommend list. You need the integration report for all the IDs.
Yes sir, I have the Lutron Integrator in Hubitat and the integration report from Lutron. I have added the ID code and everything but still nothing.
Do you have the "lutron" user and "integration" password set up on the main repeater? Depending on when and how you set it up it may have either been removed or not there to start.
Post your logs with control from both the Hubitat device and from the physical device.
Have you tried opening a Telnet connection on your computer to verify outside of Hubitat? Commands are in:
Not your issue, but you should add your main repeater as a keypad so that all the phantom buttons are available. "k,1,RadioRA 2 Main Repeater"
