Hubitat doesn't show up as a skill on my Alexa (Sonos)
I have a Sonos speaker with built-in Alexa.
When I start typing "Hubitat" in the skill search field it autocompletes but when I tap it it show "0 results found".
Can it be because my Alexa is set to French or I reside in Canada?
I had similar issues with alarm.com in the past.
I believe this is the issue.
I switched to English and now I can see it as a skill.
When I tap enable skill and type the login credentials it says unauthorized and it won't add the skill.
I see support for many other languages. Do you know if they will support French?
Others on this forum have had a similar issue. In a recent post, the user set his phone to English and was able to install the skill.
