Hubitat disconnects from cloud every night
My habitat hub disconnects from the cloud service every night and comes back every morning at exactly 5:01 AM. There are no router rule etc enabled.
This has been happening ever since I got the hub.
Any ideas?
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
:point_up_2:
This will save us asking you lots of questions if you provide the info up front.
Platform version
2.3.8.125
Hardware version
C-7
And.... questions from the post linked above
Help for Hub Related Issues
Please provide the following info (if you are not sure just say so)
Connection / Goes Offline
  • How is it connected to the LAN?
    • Ethernet / Wifi
    • Static IP set on Hub or DHCP
    • DHCP Reservation set on Router/Server?
  • How is Hub being powered? Supplied power block or other (explain)
  • Brief explanation of network topology.
  • Brief explanation of firewall / DNS / DHCP services.
  • Is Jumbo Frames enabled anywhere on the LAN?
  • How many devices total (approx) and mix between Zwave, Zigbee, LAN/Wi-fi
  • What user / custom integrations are you using for LAN/IP/Cloud based connections?
  • Screenshots of Past Logs from the incident, and also of any errors being generated recently.
It is connected via Ethernet cord into a wireless wifi point.
Static IP is enabled via the router only.
Powered by supplied power block.
Standard windows firewall.
I do not believe jumbo frame enabled anywhere.
100 z wave. 40 zigbee. No WiFi devices.
No custom integrations.
Not sure what or how to send logs.
Reset the Hub to DHCP and reserve the IP on the router.
Nevermind that's what you already have, I read it wrong.
What WiFi mesh system do you have?
Is the “wireless WiFi point” connected to the rest of your home network via a wired OR wireless connection?
As a test, maybe try connecting the HE C7 hub directly to your main router. This might help determine where the problem is.
It’s a mesh network so that one is connected wireless only.
Yes I haven’t tried connecting into the router direct yet, probably would be a good test.
TP LINK Deco x3600.
Any ideas?
Did you connect it directly to the main router yet? That will tell you what direction to look for the problem either way that test goes.
I think I might have solved it. The router put a default parental control on it which shut it down everyday from Midnight to 5:00AM. Thanks for the help!
This is to be anticipated when your hub exceeded the recommended number of child devices and apps.
