I have enabled HE Hub security and on the Dashboards all the graphs no longer work.
I suspect it is something to do with the https, is there a way to have security turned on and have graphs working in Dashboards?
Your suspicion is correct. On loading the dashboard I get 200+ js errors that mostly comprise of this
VM231 ba8d5ae0-1fbd-430a-bae0-bb5c0bd17ebd-WeatherTile2.js:778 Uncaught TypeError: Cannot read property 'close' of null
at getWeatherData (VM231 ba8d5ae0-1fbd-430a-bae0-bb5c0bd17ebd-WeatherTile2.js:778)
at VM231 ba8d5ae0-1fbd-430a-bae0-bb5c0bd17ebd-WeatherTile2.js:51
repeated over and over again.
Take a look at the units being saved by the driver. I have seen cases where copy/paste can turn your units funny in the driver code…
I’ll take a look at the error tonight …
Did you find a solution to the min/max?
I have the same problem. Did you solve it?
Thank you
I took a look and managed to solve the funny units, but still only getting what I think is the openweathermap data into the Hubigraph. The units are also Imperial, and not Metric.
I also have DarkSky weather setup and tried to get data from that, but it will also not be displayed on the weather tile.
Is there a way for me to reset the Hubigraph weather part without removing other graphs ?
Thanks for the reply. I was going to attempt to check out the values/events, but ...
again. =(
To access other devices, “Enable Hubitat Devices” under “Select Devices/Data”. To change the displayed units, set that under “Configure Tile”. When you set units you do so for all temperature, pressure, percent etc.
Just wanted to say, thank you once again for this awesome app.
It's really made my dashboards and monitoring my house 1,000 times better and easier.
Thank you
So… the error is because the dialog is null… that is weird. What browser are you using?
Is there a way to get Graphs working with Hub Security enabled?
Chrome, latest.
Hi @thomas.c.howard,
any news regarding these Time Line features?
Working it. I will probably rewrite the timeline code to run without Google Graphs and enable direct SVG creation. First I have to finish separating what I am now calling HubiWidget and HubiGraphs. As a side-note, my son is probably a few weeks from releasing HubiCode.
Not to give to much away, but he has done wonders. He has VScode integration working!
Wow, that are great news!
If you need any help... I'm ready to test, code review, or offering some
What I mean is now that the HE is has Hue Login Security enabled you can no longer access Hubigraph using the HTTPS:// Hue Login Security interface.
OK disabled Hubitat Login Security appears to cause a few issues with Hubigraph, HPM.
@thomas.c.howard - I have moved the HEs onto their own vlan, that means their IP addresses have changed.
The HEs appear to have moved across without major issue.
But the Hubigraphs all still have the OLD IP address embedded in the graphs - how do you update the graphs to use the new IP address?
You’ll need to disable/renenable Oauth Authorization….
