I cannot edit it (there is no access within the app or on the dashboard for modifying the components) - I thought i saw a post above stating this was available?
Figured that out just after i sent this message...
Editing works great!
However, on my dashboard, I still have plenty of space at the bottom of the tile
Apologies for the question, I did try and search but couldn't find the answer? My graph only appears to show a days worth of readings even though I have set it for 3 days? Is there some kind of setting I am missing? Any help or direction would be appreciated.
No issues; just take a look about 10 posts up what you are seeing is an effect of Hubitat not “storing” 1000 events anymore. Making that change had good reasons as far as performance and stability go. It really helped the hub but “broke” HubiGraphs.
There are two “work around”
Each device now has a “Event History" and "State" that is set to 101 and 30 respectively. If you change those numbers, then HubiGraphs can pull in more data without "losing it". See below.
I have implemented Long-term Storage (available from the Setup screen). This is, in my mind a better solution since it doesn't hit the hub performance.
Are you using LineGraph? LTS is implemented for TimeGraph. LineGraphs will be removed in the next release since TimeGraphs do EVERYTHING and MORE that Line Graphs support.
Now the Dashboard shows a tile with the Title and I have to click on it to see the graph.
How do I get the graph to show inline directly on the dashboard?
