I believe that I have my 2 HE hubs linked successfully via HubConnect - at least they show as 'online' so I think I have gotten that far. I'm not sure exactly what all things I might want to consider doing now that HubConnect is up and running but the first thing that occurs to me is that I'd like to have all my Dashboards on a single screen. To that end, I think I've got a hurdle to jump. The screen below indicates that I need to have two drivers installed on the master hub.
*HubConnect Dimmer
*HubComment Switch
How do I acquire these drivers and how do I install them (I guess on the server)?
Once they are properly installed I presume that I will be able to add devices that are located on the client to the server's Dashboard in the same manner as I set up the original Dashboard?
On the client, I show the 'HubConnect Remote Client" under 'Apps Code'. Additionally, on the client, there is nothing displaying under 'Drivers Code'. I presume that there should be drivers there, no?
Only if you are exporting devices from the Coordinator/Master hub to the client.
Edit - AFAICT, you are exporting only devices from the client hub to the coordinator hub. If that is true, then you will only need HubConnect drivers on the coordinator hub.
For now, I merely want to be able to control the devices (via the Dashboard) that are on the client from the server. Both the coordinator and the client are online. I have selected the devices I want to link to the coordinator hub (see image above). At the bottom of the screen I am prompted to be sure that I have HubConnect Dimmer and HubConnect Switch drivers installed. How do I tell if they have been installed?
I believe I have successfully carried out step 3, (1-4). I don't know that I need to install ALL drivers so I have not done step 4, as it says it is optional. However, if I don't install ALL the drivers, how do I install those that I need (there appear to be 2)?
Nope. HubConnect Remote Hub is the only driver that shows up in the Drivers section on my coordinator hub. So I'll need to do some copying and pasting apparently. What am I copying though? a URL? just code? And where do I find these HubConnect drivers?
I've been following the documentation you referenced. Regardless of if I try to import a single, selected driver from the github site or if I enter the supplied URL from the installation documentation for ALL the drivers, I get the same result. Looks like an error message.
A 2nd hint is to help understand where the Universal drivers get installed:
Imagine you have a real dimmer or switch. It's mounted in the wall, replacing what was there before. You Join it to a Hub and it's given a 'real driver' on that hub. The OTHER HUB gets the Universal Driver.
I have an idea for HubConnect. Would it be possible to dynamically create virtual device commands and attributes for Any shared device vs importing all these one off drivers? I realize the custom attributes feature is available but why not have the code do this automatically when evaluating a physical device driver? It could be transparent to the user and make upgrades easier in the future when distributing updated drivers across multiple remote hubs. Is there an API to remotely import a device driver on a remote hub? Just a thought.
