Updated to 2.2.113 last night and two of my devices, both Remotec ZDS-110NA z-wave switches, are no longer controlled by the hub. The device page updates their status when I physically press the button on the device, but none of the hub controls work.
Device: Remotec ZDS-110NA (I have two more of these that still work fine, which is even more strange.)
Names: "Baby humidifier" and "Baby air purifier" (I have other "Baby [device]" names that work fine, but they're a zigbee rgb bulb and lutron devices)
Actions:
I removed/readded one of the devices - didn't work
I downgraded the hub back to 2.2.0.132, restored from backup, and removed/readded the same device. Everything started working fine!
I re-upgraded to 2.2.1.113 and those two exact same devices broke!
For now I'll re-downgrade, but I figured I'd put this up in case it's useful.
Almost baby bed time here; I'll try to get you some tomorrow! I'm trying to remember exactly when in the process, but I know that at one point when it wasn't working I looked at logs and saw...nothing. But I'm probably remembering wrong. In any case, tomorrow it is!
These logs are for a Zooz Zen30 (double switch). The dimmer part isn't working for on/off commands using 2.2.1.113. On the other hand, setLevel(100) and setLevel(0) work perfectly.
Not the same as the zooz, my issue is with the remotec using the generic zwave switch driver. I just couldn't tell if your fix reply was specific or more general to the thread
Logs incoming!
EDIT: ah, looks like mobile view makes it harder to see what messages are replying to who, my bad!
