Platform 2.0.7 includes new dedicated drivers for the Iris V2, and V3 keypads.
If you are unsure which keypad you have, Hubitat supported keypads are shown here...
Once you have identified your keypad, please manually change the driver to the correct one for your device.
Iris V2 Keypad will use driver "Iris V2 Keypad"
Iris V3 Keypad will use driver "Iris V3 Keypad"
The existing CentraLite and Comcast devices will continue to use the existing centraLite driver.
It is not necessary to click configure after changing these drivers.
New device pairings should select the correct driver going forward.
