Hub Update 2.0.1
Hubitat Elevation Platform update 2.0.1 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 2.0.0:
Drivers and Devices
  • New drivers:
    • Neo Coolcam Motion Sensor
    • Zooz S2 Multisiren
    • Fibaro Dimmer 2
  • New devices:
    • NEO Coolcam Door/Window Sensor using Generic Z-Wave Contact Sensor
    • Sylvania Smart+ Outlet using Generic Zigbee Outlet
    • TKB Dimmer Socket using Generic Z-Wave Smart Dimmer
  • New driver features
New Built-in Apps
New Built-in App Features
  • Rule Machine
    • Added app events.
    • Added random messages.
    • Toggle switches and dimmers now toggles each one independently.
  • Mode Manager
    • Added app events.
    • Added other modes to use times for returning with presence.
    • Added other modes to not allow times changing mode.
  • Motion Lighting
    • Added app events.
  • Hubitat Safety Monitor and HSM Custom Rules
    • Added app events.
  • Simple Lighting
    • Added app events.
  • Hue Bridge Integration
    • Added polling option with rates, including disable.
    • Implemented transition time option for set level.
    • Implemented level change for bulb drivers.
    • Implemented Polling optimizations.
Bug Fixes
  • Mode Manager: fixed switch for mode change, one switch two modes bug.
  • Motion Lighting: fixed bug where it would not turn on thinking light was already on.
  • Hubitat Dashboard: fixed Pin dialog to be mobile compatible.
  • Fixed Apps with UI 24 hour time input not updating properly.
  • Generic Z-Wave Smart Dimmer: fixed digital command reporting issues.
  • Fixed 500 error on local OAUTH2 page.
  • Fixed mobile landscape font size increase (font now stays same size).
  • Rule Machine: fixed bug in Schedule at sunrise/sunset.
  • Hue Bridge Integration: Fix duplicate event generation.
  • Alexa Skill: Cloud traffic optimizations.
  • Fixed Hue RGBW driver color command event failure.
Hotfix 2.0.1.114 is available with bug fixes for Alexa, Hue, code folding, 24 time display in apps, and reboot/shutdown endpoint security.
Hotfix release 2.0.1.117 is available with a few bug fixes. Deleted Scene names in other apps are cleaned up (will need to open any one Scene and hit Done); correct alert devices now given for water and smoke alerts in HSM; adjustments to Hue integration to remove log spam and change wording for polling interval, recommended interval is 1 minute.
