Hub Update 1.1.1
Hubitat Elevation Software update 1.1.1 is now available:
Please note, the process takes about a minute to download (depending on your Internet connection) and extract the hub update, and 1-2 minutes to perform the update after you click 'Update Hub'. We recommend that you periodically download a backup of your setup from the Settings page, Backup and Restore.
Changes from 1.1.0:
Additions / Changes
  • Added logging for Z-Wave heal to live logging page.
  • Added ability to sync date and time from browser in Settings, make sure you do it from a browser that is in the same time zone as your hub or time will be set incorrectly.
  • Changed maximum Zigbee end devices from 20 to 32
  • Implement Z-Wave protection class
  • Hubitat Dashboard:
    • Added HSM Tile with ability to see and change Hubitat Safety Monitor Status
    • Added Return to Dashboards menu top left of each dashboard
    • Added Fitting for Attribute when has img tag
  • New drivers:
    • Aeotec TriSensor
    • Strips Multi-Sensor
    • Philips Dimmer Button Controller
    • Centralite keypad (Iris and xFinity)
    • Fibaro Door/Window Sensor 2
    • Sylvania Dimmer Switch Button Controller
  • New Integrations:
  • Rule Machine Version 2.5 (see more information)
  • Button Controller Version 1.5 (see more information )
Bug Fixes
  • Fix parsing of response in async http response: getData() returns raw string, getJson() returns parsed json.
  • Run installed() or updated() methods when apps are installed or updated from OAuth2 flow.
  • Fix parsing of Zigbee messages before passing to device driver.
  • Update Z-Wave switchColor and switchBinary for backwards compatibility.
  • Fix occasional issues with Hue Integration bridge discovery.
  • Fix error message from Alexa Integration when controlling device without a current value.
    • Fixed image tile misalignment on Edge
    • Fixed custom colors not changing if only one state was set
    • Fixed acceleration, carbon monoxide, link, music-player, presence color application
    • Fixed spacing on slider to fit better with smaller tiles
    • Fixed pin blank page if click cancel in authorization popup
    • Fixed display of level % next to icon
    • Fixed valve now sends open / closed properly
    • Fixed valve now asks are you sure?
    • Fixed sending switch on / off in rare cases
    • Fixed smaller text next to values
    • Fixed space between temperature and unit
    • Fixed display of music-player elements
Hot fix 1.1.1.113 is now available.
Fix for rare cases where hub would get stuck at 15% on a reboot
Dashboard read only flag will hide back button
Rule Machine update for Hubitat Safety Monitor
Hot fix 1.1.1.117 is now available.
misc bug fixes
Hot fix 1.1.1.118 is now available.
Fixes bug in Rule Machine 2.5 concerning sunrise and sunset offsets in conditions and trigger events.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
Hot fix 1.1.1.119 is now available
  • Fixes a bug where new hubs can't see zigbee or Z-Wave radios
  • Added timeout for HTTP calls to prevent app from hanging.
