Any chance I could get some details about the network adapter on this C7 hub? I put in a bunch of new hardware and it would be helpful in my troubleshooting. I've been working in IT for a long time and don't need hand-holding. Just some basic info to help narrow down what the issue is.
When I connect the hub to a Ubiquiti Unbiquiti Switch 48 Pro with the port set to auto I'm not getting a link. If I set it to 100 half-duplex I get a link but can't reach the hub. I have a bunch of vlans's configured and set the correct vlan as the native vlan. No other port speed or duplex settings will activate the port. If I move the hub over to another switch hanging off the Ubiquiti switch I can get it to connect at 100 half and the switch is set to auto. I can then access the C7 as usual. Vlans are configured on this switch as well with the port it's on set as the native vlan and the uplink configured as a trunk port.
Does the C7 only support 100 half-duplex? Does it connect at 100 half-duplex even when set to auto or can it use 1000 full-duplex?
Are there any known issues connecting it to the Ubiquity Switch 48 Pro?
I've re-terminated the drop in the network closet and replaced the patch cable. I'll try replacing the keystone jack and see if that helps. I'll have to go pickup a new one though as I already used up my spares.
Found the problem. The builder wired the jacks 568a and when I wired the patch panel I wired it 568b. I should have checked but I haven't seen any jacks wired like that in 20 years. The fact that all my other devices connected was throwing me off. I'm even running 10gb over a cat5e drop and it was working fine. I am going around and re-terminating all the jacks 568b.
