I'm having a problem with my c-7 (firmware 2.2.5.131) connecting at 100 half duplex. I have a cable running directly from my tp-link AX11000 router to the C-7 hub. The cable that I'm using is cat 6a, but I've tried swapping to a 5e as well. No luck. I've changed to a different port on the router, with no luck. I've tried resetting the hub to DHCP, no luck. I have NOT tried setting it to a static IP address, but I don't think that would be a problem. It's getting an IP address and operating fine using DHCP, except I can't figure out why it's always connecting at half. Any other suggestions?
I thought there was a command you could issue to change that . . .
one of the /hub/advanced/network/ commands. I don't know how they work so best consult with -
Can you set the port on the tp-link to not auto-negotiate? Not familiar with that device.
http://hubitat.local/hub/advanced/network/lanautonegconfigdisable
http://hubitat.local/hub/advanced/network/lanautonegconfigenable
http://hubitat.local/hub/advanced/network/lanautonegconfigstatus
http://hubitat.local/hub/advanced/network/lanautonegconfigtempenable
Thank you both. I was able to check the status and turn off auto config with these commands. That seems to have worked.
