I have two hubs (as do quite a few, some have 3 ), and easily get confused regarding which hub I'm controlling.
Would it be possible to have the Hub name (or ability to have a name there) in the header bar of the UI? Or anything else to distinguish which hub you're controlling, rather than have to check the IP on each page?
I'm normally at my PC which has two monitors, this makes it easier, but if on my laptop or phone, it gets a little confusing
I wasn't going to call @srwhite out as I tend to do that a lot when I'm talking about complex HE setups and I'm sure his notifications must number in the hundreds.
Hub Name in the Top Bar is probably not going to happen. This space is reserved and responsive for the Section / Page name and the 3dot menu on the right.
With that said, there are 2 potential spots for it, one is on the side menu and the other is in the messages, which has been proposed in a different thread to be enhanced with info like HSM status, current mode and could be added to like Hub Name / Location Name along with the existing messages.
My preference is to eventually expand the messages area, since 99% of the time this is empty.
Also, I'd like to show recent events, properly formatted in this drop down as well. Things like Front door was opened on 3/15/2018 4:23pm etc.
None of this is going to happen any time soon, but it has been noted and appreciate the feedback.
If you run DNS and use logical names for your hubs, would it be sufficient that those names would appear in the address (URL) bar of the browser? I guess that's a stretch, I imagine most people don't run DNS?
