I do run DNS (BIND) and yes, all my hubs show in the address bar by name. But when I have 9 tabs open across three hubs and updating source here and then jumping to another hub to click something to test then back to the log for ...
I do get on the wrong tab a couple times a night. {poor me, I know}
Since we are on this topic, it would also be nice if there was a difference in the tab icon between the hub and the forum. I often have both open (in several tabs) and it would make it easier to jump between them.
I would also like to suggest that you look at using the Vivaldi browser where you can open several tabs and show them as tiles, so you can fit the logs, apps and other in the same window.
Now that I'm also a member of the two hub club, this is something that is really needed! I would really like the hub name in the tab.
IE.
First hub: 'Hub1 - Apps', 'Hub1 - Drivers', etc.
Second Hub: 'Hub2 - Apps', 'Hub2 - Drivers', etc.
This would make things SOOOOO much easier!
@chuck.schwer
Added a while ago... Lower left hand corner.
While not in the 'tab', it's still a huge help!
Can we also get this in the header? Should be pretty easy to do..
