Is there a way to get the hub name using the Maker API? similar to accessing Hub Variables?
As a work around, why not create a string variable that is your hub name? Seems unlikely to be something that you would change often, and creating a variable isn't that much work.
Yes that would be what I would do. I was just wondering if there was a way to access the Hub name if that option existed.
There is.
One simple way is to install @thebearmay's Hub Information Driver, and then use the attribute "locationName". It has the hub's name.
Hmm, I do have that installed. Thanks
