will the access tokens for cloud access change when I enable it ?
if any custom apps will be affected with this change, how can I find them ?
what commonly used custom apps are affected ? I use Maker API, Mi Connector, Alexa Skill, InfluxDb Logger, WebCore, Tile Master 2, Unofficial Ring Connect, Life 360 with states
Bonus questions:
can I disable Hub Login Security if it does not go well for me ?
is there a way to disable local http access and force https while accessing locally ?
It secures the hub’s admin interface that’s accessed in a web browser. The other items you mentioned are not affected by this. Except certain apps could be; I’m not familiar with every app you mentioned, but if the app settings don’t have an option to add your login security details, then it’s not relevant.
Yes login security can be disabled after it’s been enabled.
You mentioned in another thread you've been using port forwarding to access your hub from the internet. You should really consider adding a password to secure access your hub.
actually I am not using port forwarding.
I am accessing the hub via VPN to my router. But I just want to learn and understand what is changing in case I need to use port forwarding in the future.
So, API endpoints are not affected if I add login security ?
tokens do not change ?
thanks.
actually it works with the default certificate.
I know the certificate can not be validated but at least the connection is encrypted.
Better than plain http
why isn't this option available directly in settings page ?
They'll have to have the login to the hub to utilize the endpoint. Most will have a place to enter your id and password so that they can perform that in the background.
no I did not enable security yet.
I just enabled https.
but the endpoint at port 8080 is not https
so http://${location.hub.localIP}:8080/hub/networkTest/ping/ STILL WORKS (replies)
but my app receives http 408 error
as I wrote above it is because the port changes.
so I can use 8443 , but it is not a good idea to change to ssl because it requires to change all endpoint accesses.
well , that works because the developer has implemented calling /login endpoint and getting a cookie there.
Then he calls the reboot endpoint with that cookie.
But I need to call shutdown with a rule machine rule.
So how can I implement it in rule machine ?
well, I can set a virtual button to trigger "rebooter" app
then activate button from rule.
but that's not nice.
I really don't like to add too many virtual buttons
It seems when I enable Hub UI SSL only, in the app if I am local or remote and I go and click Connect to Hub, it will take me to remoteaccess.aws.hubitat.com but will produce a 502 Bad Gateway error. Turn off SSL and it works again, and locally it will direct me to the local URL to the hub again. I also tried to access the remote admin via my computers browser, and I also get the same 502 error when trying to connect to the hub. Is this behavior to be expected?
