That's what I want to know too...I arm in HOME and then DISARM and the dash tile show DISARMED, yet I wait a few seconds and open a door or sensor, then it all triggers and turns on lights, alerts, and sirens.
As for logs, I still have not figured out how to do a screen shot of the ENTIRE log, so I just did a copy & paste of TEXT of the log which I have posted below. I have highlighted & noted the things that I & Hubitat did.
I basically just ARMED HOME from a keypad, I saw the dashboard change to ARMED HOME...then I disarmed and saw dashboard change to DISARMED...I then waited a few seconds & opened the Coke Room Windows Sensor to trip and then closed the sensor. As you can see from the activity, HE triggered everything just as normal, but remember, HSM showed it was DISARMED when I opened sensor.
After everything came on like a normal triggered intrusion, you'll see that I pressed button 2 on a keyfob to try to disarm, then pressed it again and stuff started turning off.
If I can do a better job of getting a screen shot or copy the log, please let me know.
**Wife is ready for me to ditch Hubitat and quit fooling around with it for security--something I don't want to do but may have to.
You can see at the bottom of the log below what I did...hope we can solve this
dev:4422019-06-27 09:30:50.509 am traceAlexa Playlists Changed to [:]
dev:4462019-06-27 09:30:48.041 am traceAlexa Playlists Changed to [:]
dev:4472019-06-27 09:30:47.715 am traceAlexa Playlists Changed to [:]
app:3682019-06-27 09:30:47.698 am debugDevice Data Received and Updated for (10) Alexa Devices | Took: (1964ms) | Last Refreshed: (10.0 minutes)
dev:4452019-06-27 09:30:47.303 am traceAlexa Playlists Changed to [:]
dev:4442019-06-27 09:30:47.149 am traceAlexa Playlists Changed to [:]
dev:4422019-06-27 09:30:46.458 am traceAlexa Playlists Changed to [:]
dev:4412019-06-27 09:30:45.734 am traceAlexa Playlists Changed to [:]
dev:4402019-06-27 09:30:45.254 am traceAlexa Playlists Changed to [:]
app:3682019-06-27 09:30:45.125 am debugAmazon Device Name Change Detected... Updating Device Name to (Echo - Echo Coke) | Old Name: (Echo - Coke Room)
dev:4392019-06-27 09:30:44.567 am traceAlexa Playlists Changed to [:]
app:3682019-06-27 09:30:44.564 am debugAmazon Device Name Change Detected... Updating Device Name to (Echo - Echo Kitchen) | Old Name: (Echo - Kitchen)
dev:4382019-06-27 09:30:43.664 am traceAlexa Playlists Changed to [:]
app:3682019-06-27 09:30:43.610 am debugAmazon Device Name Change Detected... Updating Device Name to (Echo - Echo Office) | Old Name: (Echo - Office)
dev:4412019-06-27 09:30:43.497 am traceAlexa Playlists Changed to [:]
app:3682019-06-27 09:30:43.100 am debugAmazon Device Name Change Detected... Updating Device Name to (Echo - Echo BR) | Old Name: (Echo - Bedroom)
dev:4462019-06-27 09:30:42.626 am traceAlexa Playlists Changed to [:]
dev:4392019-06-27 09:30:39.440 am traceAlexa Playlists Changed to [:]
dev:4442019-06-27 09:30:29.801 am traceAlexa Playlists Changed to [:]
dev:4382019-06-27 09:30:26.376 am traceAlexa Playlists Changed to [:]
dev:4402019-06-27 09:30:23.493 am traceAlexa Playlists Changed to [:]
dev:9152019-06-27 09:30:23.251 am infoBackyard Light is off [digital]
dev:9152019-06-27 09:30:23.181 am infoBackyard Light is off [digital]
app:2632019-06-27 09:30:21.228 am tracerestStreamHandler(close: false, src: startStopStream(start stream)), resetPoll: true
dev:9042019-06-27 09:30:19.593 am infoFoyer Carport Switch was turned off [digital]
dev:9152019-06-27 09:30:19.028 am infoBackyard Light is off [digital]
dev:9152019-06-27 09:30:18.941 am infoBackyard Light is off [digital]
dev:9152019-06-27 09:30:18.884 am infoBackyard Light is off [digital]
dev:9132019-06-27 09:30:18.857 am infoHallway is off [digital]
dev:9152019-06-27 09:30:18.665 am infoBackyard Light is off [digital]
dev:9132019-06-27 09:30:18.605 am infoHallway is off [digital]
dev:9152019-06-27 09:30:18.596 am infoBackyard Light is off [digital]
dev:9152019-06-27 09:30:18.547 am infoBackyard Light was turned off [digital]
dev:9132019-06-27 09:30:18.385 am infoHallway is off [digital]
dev:9022019-06-27 09:30:18.370 am infoCoke Fan 2 was turned off [digital]
dev:9132019-06-27 09:30:18.292 am infoHallway is off [digital]
dev:9132019-06-27 09:30:18.223 am infoHallway was turned off [digital]
dev:4122019-06-27 09:30:18.097 am infoHearth Plug 2 is off [physical]
dev:4122019-06-27 09:30:18.035 am infoHearth Plug 2 is off [physical]
dev:4122019-06-27 09:30:17.989 am infoHearth Plug 2 is off [physical]
dev:4122019-06-27 09:30:17.918 am infoHearth Plug 2 is off [physical]
dev:4122019-06-27 09:30:17.806 am infoHearth Plug 2 is off [physical]
dev:4122019-06-27 09:30:17.781 am infoHearth Plug 2 is off [physical]
dev:4122019-06-27 09:30:17.545 am infoHearth Plug 2 is off [physical]
dev:4112019-06-27 09:30:17.398 am infoHearth Plug 1 is off [physical]
dev:8982019-06-27 09:30:17.388 am infoDining Room Switch was turned off [digital]
dev:4122019-06-27 09:30:17.271 am infoHearth Plug 2 is off [physical]
dev:8992019-06-27 09:30:17.097 am infoCoke Fan 1 was turned off [digital]
app:2632019-06-27 09:30:16.973 am info Gathering Latest Nest Structure Data (Last Updated: 88 seconds ago)
dev:4112019-06-27 09:30:16.812 am infoHearth Plug 1 is off [physical]
dev:4112019-06-27 09:30:16.635 am infoHearth Plug 1 is off [physical]
dev:4112019-06-27 09:30:16.484 am infoHearth Plug 1 is off [physical]
dev:4112019-06-27 09:30:16.316 am infoHearth Plug 1 is off [physical]
dev:4122019-06-27 09:30:16.232 am infoHearth Plug 2 is off [physical]
dev:4122019-06-27 09:30:16.189 am infoHearth Plug 2 is off [physical]
dev:4112019-06-27 09:30:16.175 am infoHearth Plug 1 is off [physical]
dev:4122019-06-27 09:30:16.112 am infoHearth Plug 2 is off [physical]
dev:6982019-06-27 09:30:15.884 am infoPatio Lights was turned off [digital]
dev:8942019-06-27 09:30:15.825 am infoFloodlight is off [physical]
dev:8942019-06-27 09:30:15.763 am infoFloodlight is off [physical]
dev:4122019-06-27 09:30:15.680 am infoHearth Plug 2 is off [physical]
dev:8942019-06-27 09:30:15.645 am infoFloodlight is off [physical]
dev:4122019-06-27 09:30:15.610 am infoHearth Plug 2 is off [physical]
dev:4122019-06-27 09:30:15.481 am infoHearth Plug 2 is off [physical]
dev:8942019-06-27 09:30:15.411 am infoFloodlight is off [physical]
dev:4112019-06-27 09:30:15.352 am infoHearth Plug 1 is off [physical]
dev:4112019-06-27 09:30:15.292 am infoHearth Plug 1 is off [physical]
dev:12732019-06-27 09:30:15.049 am infoHallway Keypad is inactive
dev:4122019-06-27 09:30:15.008 am infoHearth Plug 2 is off [physical]
dev:4122019-06-27 09:30:14.984 am infoHearth Plug 2 is off [physical]
dev:4112019-06-27 09:30:14.957 am infoHearth Plug 1 is off [physical]
dev:4122019-06-27 09:30:14.884 am infoHearth Plug 2 is off [physical]
dev:8962019-06-27 09:30:14.852 am infoKitchen Switch is off [physical]
dev:8942019-06-27 09:30:14.746 am infoFloodlight is off [physical]
dev:8942019-06-27 09:30:14.709 am infoFloodlight is off [physical]
dev:4112019-06-27 09:30:14.699 am infoHearth Plug 1 is off [physical]
dev:4112019-06-27 09:30:14.682 am infoHearth Plug 1 is off [physical]
dev:8942019-06-27 09:30:14.625 am infoFloodlight is off [physical]
dev:4112019-06-27 09:30:14.570 am infoHearth Plug 1 is off [physical]
dev:4112019-06-27 09:30:14.537 am infoHearth Plug 1 is off [physical]
dev:8962019-06-27 09:30:14.534 am infoKitchen Switch is off [physical]
dev:8942019-06-27 09:30:14.210 am infoFloodlight is off [physical]
dev:8942019-06-27 09:30:14.197 am infoFloodlight is off [physical]
dev:8942019-06-27 09:30:14.175 am infoFloodlight is off [physical]
dev:4582019-06-27 09:30:13.966 am infoFront Entrance was turned off[digital]
dev:8962019-06-27 09:30:13.441 am infoKitchen Switch is off [physical]
dev:8962019-06-27 09:30:13.222 am infoKitchen Switch was turned off[digital]
dev:2142019-06-27 09:30:13.177 am infoFront Porch was turned off [digital]
dev:8942019-06-27 09:30:12.221 am infoFloodlight is off [physical]
dev:4122019-06-27 09:30:11.867 am infoHearth Plug 2 is off [physical]
dev:12412019-06-27 09:30:11.846 am infoDean's Bathroom is off [physical]
dev:12412019-06-27 09:30:11.780 am infoDean's Bathroom is off [physical]
dev:8942019-06-27 09:30:11.749 am infoFloodlight is off [physical]
dev:12412019-06-27 09:30:11.555 am infoDean's Bathroom is off [physical]
dev:4122019-06-27 09:30:11.531 am infoHearth Plug 2 is off [physical]
dev:12412019-06-27 09:30:11.461 am infoDean's Bathroom is off [physical]
dev:12412019-06-27 09:30:11.418 am infoDean's Bathroom is off [physical]
dev:4112019-06-27 09:30:10.956 am infoHearth Plug 1 is off [physical]
dev:4112019-06-27 09:30:10.749 am infoHearth Plug 1 is off [physical]
dev:4122019-06-27 09:30:10.642 am infoHearth Plug 2 is off [physical]
dev:8952019-06-27 09:30:10.623 am infoGarage Lights is off [physical]
dev:4122019-06-27 09:30:10.533 am infoHearth Plug 2 is off [physical]
dev:8952019-06-27 09:30:10.526 am infoGarage Lights is off [physical]
dev:4112019-06-27 09:30:10.465 am infoHearth Plug 1 is off [physical]
dev:4122019-06-27 09:30:10.462 am infoHearth Plug 2 was turned off[digital]
dev:8952019-06-27 09:30:10.378 am infoGarage Lights is off [physical]
dev:8952019-06-27 09:30:10.225 am infoGarage Lights was turned off[digital]
dev:12412019-06-27 09:30:09.553 am infoDean's Bathroom is off [physical]
dev:8942019-06-27 09:30:09.510 am infoFloodlight is off [physical]
dev:8942019-06-27 09:30:09.327 am infoFloodlight is off [physical]
dev:8942019-06-27 09:30:09.252 am infoFloodlight is off [physical]
dev:12412019-06-27 09:30:09.229 am infoDean's Bathroom is off [physical]
dev:4112019-06-27 09:30:08.878 am infoHearth Plug 1 is off [physical]
dev:4112019-06-27 09:30:08.606 am infoHearth Plug 1 is off [physical]
dev:4112019-06-27 09:30:08.198 am infoHearth Plug 1 is off [physical]
dev:12412019-06-27 09:30:07.678 am infoDean's Bathroom is off [physical]
dev:12412019-06-27 09:30:07.539 am infoDean's Bathroom is off [physical]
dev:12412019-06-27 09:30:07.241 am infoDean's Bathroom is off [physical]
dev:8942019-06-27 09:30:06.649 am infoFloodlight is off [physical]
dev:8942019-06-27 09:30:06.111 am infoFloodlight was turned off[digital]
dev:4112019-06-27 09:30:06.030 am infoHearth Plug 1 is off [physical]
dev:4112019-06-27 09:30:05.819 am infoHearth Plug 1 was turned off[digital]
dev:12412019-06-27 09:30:05.553 am infoDean's Bathroom is off [physical]
dev:12422019-06-27 09:30:05.201 am infoRecessed Lights is off [physical]
dev:12422019-06-27 09:30:05.083 am infoRecessed Lights is off [physical]
dev:12412019-06-27 09:30:05.035 am infoDean's Bathroom was turned off[digital]
dev:4452019-06-27 09:30:04.608 am traceAlexa Playlists Changed to [:]
dev:12422019-06-27 09:30:04.033 am infoRecessed Lights is off [physical]
dev:12422019-06-27 09:30:03.988 am infoRecessed Lights was turned off[digital]
app:2632019-06-27 09:30:03.658 am tracerestStreamHandler(close: false, src: startStopStream(start stream)), resetPoll: true
dev:11762019-06-27 09:30:00.157 am infoOffice Lamp is on [physical]
dev:4472019-06-27 09:29:59.529 am traceAlexa Playlists Changed to [:]
app:2632019-06-27 09:29:59.450 am info Gathering Latest Nest Device Data (Last Updated: 95 seconds ago)
dev:11762019-06-27 09:29:58.655 am infoOffice Lamp is on [digital]
dev:9082019-06-27 09:29:58.583 am infoBedroom Light was turned off[digital]
dev:4422019-06-27 09:29:50.548 am traceAlexa Playlists Changed to [:]
dev:12732019-06-27 09:29:48.241 am infoHallway Keypad was disarmed [physical]
dev:12732019-06-27 09:29:45.000 am infoHallway Keypad is active
dev:4412019-06-27 09:29:43.512 am traceAlexa Playlists Changed to [:]
dev:4462019-06-27 09:29:42.570 am traceAlexa Playlists Changed to [:]
dev:4392019-06-27 09:29:39.576 am traceAlexa Playlists Changed to [:]
dev:8062019-06-27 09:29:31.964 am infoLamp was turned off
app:1162019-06-27 09:29:31.827 am warnAlert Intrusion-Home canceled
dev:4182019-06-27 09:29:31.030 am infoTanya Keyfob button 2 was pushed
dev:4442019-06-27 09:29:29.571 am traceAlexa Playlists Changed to [:]
dev:4382019-06-27 09:29:26.377 am traceAlexa Playlists Changed to [:]
dev:4402019-06-27 09:29:23.502 am traceAlexa Playlists Changed to [:]
dev:9132019-06-27 09:29:13.659 am infoHallway is 99% [digital]
dev:9132019-06-27 09:29:13.654 am infoHallway is on [digital]
dev:4452019-06-27 09:29:04.578 am traceAlexa Playlists Changed to [:]
NOTE: At this point, all lights & sirens were on as supposed to be when triggered
& I pressed keyfob button #2 to DISARM--I pushed it a 2nd time as you will see above to try to turn things off..then things stared turning off)
dev:4182019-06-27 09:29:03.812 am infoTanya Keyfob button 2 was held
dev:12422019-06-27 09:29:01.432 am infoRecessed Lights is on [physical]
dev:12422019-06-27 09:29:01.123 am infoRecessed Lights is on [physical]
dev:12422019-06-27 09:29:01.059 am infoRecessed Lights is on [physical]
dev:12422019-06-27 09:29:01.030 am infoRecessed Lights is on [physical]
dev:12422019-06-27 09:29:00.902 am infoRecessed Lights is on [physical]
dev:12422019-06-27 09:29:00.859 am infoRecessed Lights is on [physical]
app:3682019-06-27 09:29:00.739 am errorgroovy.lang.MissingMethodException: No signature of method: com.hubitat.hub.executor.AppExecutor.error() is applicable for argument types: (org.codehaus.groovy.runtime.GStringImpl, java.lang.Exception) values: [sendMsg Push Message Exception:, java.lang.Exception: Invalid phone number, numbers must start with + and be followed by country code and phone number]
Possible solutions: render(), getLog(), now(), iterator(), every(), grep() on line 1783 (healthCheck)
app:3682019-06-27 09:29:00.445 am infoSuccessfully Retrieved (v1.0) of AppData Content from GitHub Repo...
dev:4472019-06-27 09:28:59.793 am traceAlexa Playlists Changed to [:]
dev:12422019-06-27 09:28:58.378 am infoRecessed Lights is on [physical]
dev:12422019-06-27 09:28:58.294 am infoRecessed Lights is on [physical]
app:2632019-06-27 09:28:58.261 am tracerestStreamHandler(close: false, src: startStopStream(start stream)), resetPoll: true
dev:12422019-06-27 09:28:57.033 am infoRecessed Lights is on [physical]
dev:12422019-06-27 09:28:55.855 am infoRecessed Lights is on [physical]
dev:12422019-06-27 09:28:54.724 am infoRecessed Lights was turned on[digital]
dev:12412019-06-27 09:28:53.370 am infoDean's Bathroom was turned on[digital]
app:2632019-06-27 09:28:53.200 am info Skipping Poll - Devices Data Updated: (30sec) ago | Structure Data Updated: (5sec) ago
app:2632019-06-27 09:28:52.224 am tracerestStreamHandler(close: false, src: startStopStream(start stream)), resetPoll: true
dev:4422019-06-27 09:28:50.520 am traceAlexa Playlists Changed to [:]
app:2632019-06-27 09:28:48.317 am info Gathering Latest Nest Structure Data (Last Updated: 85 seconds ago)
dev:11762019-06-27 09:28:47.940 am infoOffice Lamp is on [digital]
dev:9152019-06-27 09:28:47.927 am infoBackyard Light is on [digital]
dev:9152019-06-27 09:28:47.852 am infoBackyard Light was turned on [digital]
dev:9042019-06-27 09:28:47.719 am infoFoyer Carport Switch was turned on [digital]
dev:9132019-06-27 09:28:47.556 am infoHallway is 99% [digital]
dev:9132019-06-27 09:28:47.553 am infoHallway is on [digital]
dev:9132019-06-27 09:28:47.386 am infoHallway is 99% [digital]
dev:9132019-06-27 09:28:47.377 am infoHallway is on [digital]
dev:9022019-06-27 09:28:47.166 am infoCoke Fan 2 was turned on [digital]
dev:9132019-06-27 09:28:47.007 am infoHallway is 99% [digital]
dev:9132019-06-27 09:28:47.004 am infoHallway is on [digital]
dev:9132019-06-27 09:28:46.973 am infoHallway is 99% [digital]
dev:9132019-06-27 09:28:46.970 am infoHallway is on [digital]
dev:9132019-06-27 09:28:46.715 am infoHallway is 99% [digital]
dev:9132019-06-27 09:28:46.713 am infoHallway is on [digital]
dev:9132019-06-27 09:28:46.683 am infoHallway is 99% [digital]
dev:9132019-06-27 09:28:46.680 am infoHallway was turned on [digital]
dev:8942019-06-27 09:28:45.384 am infoFloodlight is on [physical]
dev:8942019-06-27 09:28:45.329 am infoFloodlight is on [physical]
dev:8942019-06-27 09:28:45.154 am infoFloodlight is on [physical]
dev:8942019-06-27 09:28:45.000 am infoFloodlight is on [physical]
dev:8942019-06-27 09:28:44.946 am infoFloodlight is on [physical]
dev:8962019-06-27 09:28:44.516 am infoKitchen Switch is on [physical]
dev:8952019-06-27 09:28:44.010 am infoGarage Lights is on [physical]
dev:8952019-06-27 09:28:43.911 am infoGarage Lights is on [physical]
dev:8952019-06-27 09:28:43.886 am infoGarage Lights is on [physical]
dev:8952019-06-27 09:28:43.832 am infoGarage Lights is on [physical]
dev:8952019-06-27 09:28:43.692 am infoGarage Lights was turned on[digital]
dev:4412019-06-27 09:28:43.548 am traceAlexa Playlists Changed to [:]
dev:8942019-06-27 09:28:42.606 am infoFloodlight is on [physical]
dev:4462019-06-27 09:28:42.529 am traceAlexa Playlists Changed to [:]
dev:8962019-06-27 09:28:42.281 am infoKitchen Switch is on [physical]
dev:8962019-06-27 09:28:42.086 am infoKitchen Switch is on [physical]
dev:8942019-06-27 09:28:41.795 am infoFloodlight is on [physical]
dev:8942019-06-27 09:28:41.074 am infoFloodlight is on [physical]
dev:8992019-06-27 09:28:41.003 am infoCoke Fan 1 was turned on [digital]
dev:9082019-06-27 09:28:40.996 am infoBedroom Light was turned on[digital]
dev:8982019-06-27 09:28:40.691 am infoDining Room Switch was turned on [digital]
dev:8942019-06-27 09:28:40.609 am infoFloodlight is on [physical]
dev:8962019-06-27 09:28:40.315 am infoKitchen Switch is on [physical]
dev:8962019-06-27 09:28:40.070 am infoKitchen Switch was turned on[digital]
dev:8942019-06-27 09:28:39.705 am infoFloodlight is on [physical]
dev:4392019-06-27 09:28:39.450 am traceAlexa Playlists Changed to [:]
dev:8942019-06-27 09:28:39.301 am infoFloodlight was turned on[digital]
dev:2792019-06-27 09:28:32.614 am infoCarport Keypad is inactive
dev:4442019-06-27 09:28:29.532 am traceAlexa Playlists Changed to [:]
app:2632019-06-27 09:28:27.215 am tracerestStreamHandler(close: false, src: startStopStream(start stream)), resetPoll: true
dev:4382019-06-27 09:28:26.454 am traceAlexa Playlists Changed to [:]
dev:4402019-06-27 09:28:23.781 am traceAlexa Playlists Changed to [:]
app:2632019-06-27 09:28:23.545 am info Gathering Latest Nest Device Data (Last Updated: 59 seconds ago)
dev:6982019-06-27 09:28:22.524 am infoPatio Lights was turned on [physical]
dev:6982019-06-27 09:28:22.418 am infoPatio Lights was turned on [digital]
dev:4582019-06-27 09:28:22.222 am infoFront Entrance was turned on[digital]
dev:4122019-06-27 09:28:22.210 am infoHearth Plug 2 was turned on[digital]
dev:2142019-06-27 09:28:21.853 am infoFront Porch was turned on [digital]
dev:4112019-06-27 09:28:21.836 am infoHearth Plug 1 was turned on[digital]
NOTE: I closed window sensor just after opening it.
dev:192019-06-27 09:28:13.033 am infoWindow Sensor Coke Room 1 was closed
dev:8922019-06-27 09:28:12.093 am info0501 skipped: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:28:12.090 am debugdescMap: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:28:12.083 am info0501 skipped: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:28:12.076 am debugdescMap: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:28:12.047 am info0501 skipped: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:28:12.043 am debugdescMap: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:3802019-06-27 09:28:11.446 am infoLiving Room Sonos is stopped
dev:3802019-06-27 09:28:09.223 am infoLiving Room Sonos is playing
dev:3802019-06-27 09:28:09.110 am infoLiving Room Sonos audio level is 100%
dev:3802019-06-27 09:28:08.782 am infoLiving Room Sonos audio level is 50%
dev:12732019-06-27 09:28:08.694 am infoHallway Keypad is inactive
dev:932019-06-27 09:28:08.047 am infoSending Message: [Intrusion! Window Sensor Coke Room 1 is open at 09:28 AM on 06/27/2019] Priority: [0] to [All Devices]
dev:8062019-06-27 09:28:07.435 am infoLamp was turned on
dev:12732019-06-27 09:28:06.631 am infoHallway Keypad was disarmed [digital]
app:1162019-06-27 09:28:05.698 am warnAlert Intrusion-Home Window Sensor Coke Room 1 open
dev:10312019-06-27 09:28:05.508 am infoPatio Keypad was disarmed [digital]
dev:8922019-06-27 09:28:05.294 am info0501 skipped: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:28:05.280 am debugdescMap: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
NOTE: HSM Dashboard was showing DISARMED when I opened this window sensor.
dev:192019-06-27 09:28:05.037 am infoWindow Sensor Coke Room 1 was opened
dev:4452019-06-27 09:28:04.631 am traceAlexa Playlists Changed to [:]
dev:8922019-06-27 09:28:04.327 am infoKitchen Keypad was disarmed [digital]
dev:8922019-06-27 09:28:03.314 am tracesendArmResponse- sucess, bin:1, armMode:00 -> armRequest:00, exitDelay:0, isInitiator:false, lcData:[isValid:true, isInitiator:false, code:0000, name:not required, codeNumber:-1]
dev:8922019-06-27 09:28:03.297 am info0501 skipped: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:28:03.294 am debugdescMap: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:2822019-06-27 09:28:03.279 am infoBedroom Keypad was disarmed [digital]
dev:2792019-06-27 09:28:02.584 am infoCarport Keypad is active
dev:2792019-06-27 09:28:02.265 am infoCarport Keypad was disarmed [digital]
dev:8922019-06-27 09:28:01.313 am info0501 skipped: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:28:01.310 am debugdescMap: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:28:01.285 am info0501 skipped: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:28:01.279 am debugdescMap: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:12732019-06-27 09:28:01.244 am infoHallway Keypad was disarmed [digital]
dev:10312019-06-27 09:28:00.198 am infoPatio Keypad was disarmed [digital]
dev:4472019-06-27 09:27:59.631 am traceAlexa Playlists Changed to [:]
dev:8922019-06-27 09:27:59.175 am infoKitchen Keypad was disarmed [digital]
dev:8922019-06-27 09:27:58.194 am tracesendArmResponse- sucess, bin:1, armMode:01 -> armRequest:00, exitDelay:0, isInitiator:false, lcData:[isValid:true, isInitiator:false, code:0000, name:not required, codeNumber:-1]
dev:2822019-06-27 09:27:58.169 am infoBedroom Keypad was disarmed [digital]
dev:2792019-06-27 09:27:57.159 am infoCarport Keypad was disarmed [digital]
app:1162019-06-27 09:27:55.824 am infoDisarmed
NOTE: At this point HSM in Dashboard showed DISARMED as normal & I waited about
10 seconds to open contact sensor.
dev:12732019-06-27 09:27:55.530 am infoHallway Keypad was disarmed [physical]
app:2632019-06-27 09:27:52.682 am tracerestStreamHandler(close: false, src: startStopStream(start stream)), resetPoll: true
dev:4422019-06-27 09:27:50.683 am traceAlexa Playlists Changed to [:]
dev:8922019-06-27 09:27:49.868 am info0501 skipped: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:27:49.830 am debugdescMap: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:2792019-06-27 09:27:49.791 am infoCarport Keypad is inactive
dev:8922019-06-27 09:27:48.811 am info0501 skipped: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:27:48.808 am debugdescMap: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:27:48.793 am info0501 skipped: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:27:48.789 am debugdescMap: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:27:48.781 am info0501 skipped: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
dev:8922019-06-27 09:27:48.778 am debugdescMap: [raw:catchall: 0104 0501 01 01 0040 00 ED52 00 00 0000 0B 00 0400, profileId:0104, clusterId:0501, clusterInt:1281, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:ED52, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:00, data:[04, 00]]
app:2632019-06-27 09:27:47.646 am info Skipping Poll - Devices Data Updated: (24sec) ago | Structure Data Updated: (25sec) ago
dev:10312019-06-27 09:27:46.362 am infoPatio Keypad was armed home [digital]
dev:8922019-06-27 09:27:45.346 am infoKitchen Keypad was armed home [digital]
dev:8922019-06-27 09:27:44.369 am tracesendArmResponse- sucess, bin:1, armMode:00 -> armRequest:01, exitDelay:0, isInitiator:false, lcData:[isValid:true, isInitiator:false, code:0000, name:not required, codeNumber:-1]
dev:8922019-06-27 09:27:44.366 am debugarmHome(0, armMode:00, armingMode:00)
dev:2822019-06-27 09:27:44.333 am infoBedroom Keypad was armed home [digital]
dev:4412019-06-27 09:27:43.396 am traceAlexa Playlists Changed to [:]
dev:2792019-06-27 09:27:43.282 am infoCarport Keypad was armed home [digital]
dev:4462019-06-27 09:27:42.857 am traceAlexa Playlists Changed to [:]
app:1162019-06-27 09:27:41.913 am infoArmed Home
dev:12732019-06-27 09:27:41.757 am infoHallway Keypad was armed home [physical]
dev:4392019-06-27 09:27:39.507 am traceAlexa Playlists Changed to [:]
dev:12732019-06-27 09:27:38.669 am infoHallway Keypad is active
