HSM mirrors Ring Alarm
I want to arm my ring alarm on my ring app, but I want the Hubitat security to mirror the modes from my ring alarm app? Can I use IFTTT or is there a way to make this work.
I tried the work around for ring to mirror Hubitat but it would fail from time to time so I need something to mirror ring modes instead.
You could install the community integration to Ring and then use it or Rule Machine to mirror HSM modes to Ring.
Can you walk me through it? I want to change the mode on the ring app and have Hubitat mirror it.
Let’s start with step 1, to install the Hubitat Package Manager. Instructions can be found here:
Then you will need to install this integration from Hubitat Package Manager (HPM):
I have everything all set up. How do I set up the rules? I figured out how to have ring mirror the HSM, but I would like to have HSM mirror Ring.
I set up this rule and HSM is not mirroring Ring or doing anything. I woul like to set up the following:
When I set these Ring modes:
Ring - Arm Away changes HSM Mode to Away
Ring - Arm Home changes HSM Mode to Armed Home
Ring - Disarmed changes HSM Mode to Disarm
It changes the status but not the modes
This is the rule that I have created for this:
This worked! You rock man!
