Hi all, my HPM stopped working and I was looking for some assistance please.
This is what I get when I try to load it:
I've uninstalled it fully and reinstalled it but it won't load, see logs:
Please can someone assist?
Given the problem here and in your other post, I wonder if your hub doesn't have an Internet connectivity problem. To investigate,
github.com
or cloud.hubitat.com
(or some other Internet hostname) and then click Ping.If there are errors, either try a network reset or make sure the settings on the Network Setup page are correct for you (DCHP is easiest, but if you're not using it, make sure you have valid DNS servers — a common cause of problems like this).
Thanks a lot for the prompt response.
I've switched it back to DHCP and it's all sorted now including HPM.
Cheers.
This topic has been marked solved and subsequently closed. For further discussion on this subject or related issues, feel free to create a new thread under an appropriate category.
If you are logged in, click [HERE] to get started.
