Hi,
First time user here. I'm using the simple automation rules to turn on a light at sunset and then turn it off using a variable time. When I click on variable option I get this popup that states "Time Variable Connector * Click to Set"
When I click on it there's a box that states "Update" Clicking it it does nothing. Can someone point me to the documentation that explains how to use/set this up? I've looked and can't find any good explanation.
Did you create a time variable in Rule Machine first? Then create a connector for it in the same place. That creates a virtual device of the same name as the variable -- that is the connector. Attach that to a tile in a Dashboard if you want.
I second this question. There was nothing in the simple automation rule that indicated that a variable time is something that has to be created externally and selected. The linked help page goes to simple lighting, not simple automation, but even the simple automation page has no details on variable time.
We are working to update the documentation, and more is coming soon on this subject for the 2.2.8 release.
To use a time variable for Variable Time in apps, you must create a connector for the time variable (it will have the same name as the variable). Then, select that device from the pull down in the app offered for Variable Time.
Changing the variable's value changes the connector's value, and adjusts the app accordingly. Changing the connector value does the same thing, and also changes the variable value. Variable and connector are two sides of the same coin.
I'm having an issue with a time variable displaying off by one hour. I set sunrise and sunset variables via a rule, and they have connectors. The variables show the correct times in Rule Machine:
Perhaps you should switch to a Hub Variable and RM 5.0. There were changes made to the Dashboard templates. Rather than try to sort that out, creating new would make more sense.
