I think there is a bug with having Wait for a variable Certain Time, like what you have.
But, it works correctly if you use the second (backwards) one I showed above. By work correctly, I mean update the scheduled events correctly if the variable time changes.
I've had so many issues with the latest release 2.2.9.140.
I even ended up with a corrupt database and had to restore.
Hub Variables do not work and I get an Unexpected Error TO message.
Local Variable used in RM no longer work, and if I change the time (as set in my dashboards) I get a bad time message, where this used to work perfectly !
Please update to the latest release at Settings / Check for Updates. After you try that, please show me with screenshots exactly what problem you have.
Best thing for you is to restore from the backup just made. I don't know what happened with that variable. If you can detail exact steps you took maybe I can reproduce it. Right down to nit details of how you set it in the first place, and what you did with the Dashboard.
I did the restore and checked the hub variables.
My test variable was now working.
I added the test variable to a dashboard and changed the time value.
Checked the hub variable again and it was in error.
Restoring the hub backup again.
What variable should I be using to control time ON and OFF of some lights in RM, with the variables being adjustable from the dashboard ? Hub Variable ? Local Variable ? RM Legacy Variable ?
Thanks! We know exactly what is happening any why. A fix for this issue will be in the next release. There is an incompatibility between the way Javascript handles time strings and the way Hub Variables handles them. Easy to correct.
Sorry for the inconvenience, and thanks for you help and patience!
