aaiyar
March 11, 2020, 3:52pm
1
@chuck.schwer @bobbyD
I've three HSM modes (armedAway, armedHome, and armedNight). Although I can retrieve the current HSM mode via Maker-API, I'm unable to change the HSM mode.
I've tried using httpget URLs structured as follows (for example):
http://hub-ip-address/apps/api/Maker-API-app-id/hsm/armedAway?access_token=Maker-API-Access-Token
I can Mode changes to work just fine, so I know the hub ip address, Maker-API-app-id, and access token are ok.
Thanks much!
Try disarm, armAway, armHome or armNight. armedAway is the status, armAway is the command.
aaiyar
March 11, 2020, 7:24pm
3
Thanks! Tore the rest of hair out earlier ...
aaiyar:
What is the link you are using the change mode?
UPDATE: Never mind...I found it. Thanks!!
It was released roughly April 29th...
almost 90 days ago.
[50%20AM]
system
Closed
September 23, 2022, 11:22am
5
