I need to revert back to firmware 1.0.8, as I need the dashboard to work properly. I restored a back-up from today, but the firmware is still 1.0.9. I tried a back-up from yesterday, same thing. How do I revert the firmware?
Contact @bobbyD for support
Use port 8081
That did it, thanks!
We just put up a hot fix for the dashboard issues.
Reviving this thread maybe
When I revert to older firmware, all my devices will remain paired right (bc they are stored in the stick)?
Will I need to load a backup to get all the devices showing up again in the UI? If so- can that be a recent backup?
Thoughts?
As stated on the other thread you have on this subject, the firmware version and the database are independent. Restoring one does not affect the other. Restoring a database will not revert the firmware also and reverting the firmware, will not restore an old database.
