How to: Flash SonOff USB Dongle to be a Zigbee Repeater/Router & Set Transmit Power
What worked for me was:
Remove the dongle after flashing.
Start pairing on the hub before inserting the newly flashed dongle into a 110v to USB adapter.
Worked several times for me so far. :crossed_fingers:
Note: This was using the Windows/Python flashing procedure for a "P" dongle.
You only plugged it into mains power once after flashing and after starting pairing? Without pressing or holding Reset?
Correct.
When using the Windows/Python method the dongle cover is not removed, so no way to push the button.
And sometimes i am just blown away by just what the hubitat system can do.
OMG it's 2025 and this is still so complicated.
Need to be able to plug in and press OTA
ok had a lot of trouble getting one of these to flash on my windows 11 computer with only a usb c port..
first you need to install the older version of this
https://www.silabs.com/documents/public/software/CP210x_Windows_Drivers_with_Serial_Enumeration.zip
unzip and run the x64 installer .exe
the you need to install this
need to put a request in that you are not exporting it.. if you cant get it drop me a line and ill send a link to my ftp site
then the bigge i had trouble finding a cable that fully worked with the usb 3.0 port
this is the one on amazon i found..
Thanks...I'll update the first or second post w/this info soon...
