tj1
August 31, 2021, 2:23am
1
I added RING RANGE EXTENDER 2nd Gen to the hub, it added fine (non secure) but im not sure if it's working.. all seems normal in the hub
i've placed the extender where I am sure my hub can reach... and further away got a z-wave button to test - but unfortunately, button still not working ... I checked the range extender's device event and it showed only the battery levels, No other clues
so im blind as to this extender is really working or not.
if you're on a C-7, you can look at the topology
tj1
August 31, 2021, 4:52am
6
I'm on C7.. i'll explore z-wave topology
tj1
August 31, 2021, 10:26am
7
so im trying to understand this..
my fibaro remote is 0E
and the repeater is 14
they both in blue so should see each other
but signal from fibaro not getting to hub (rule to sound siren didn't fire) .. so i guess it's not working at all..
njanda
August 31, 2021, 10:48am
8
Have a look at the last column in the zwave Radio Device Table as it shows the node addresses.
Under z-wave settings note the number of the repeater, then look at your other devices for that number in the routes
Always forget which way to read this, but if I’m doing it correctly:
0x14 sees 0x13, 0x11 and the hub (0x01), and is seen by 0x0A, 0x11, 0x13 and the hub
0x0E doesn’t appear to see or be seen by anything except the hub
I may have the sees/seen reversed, but regardless 0x0E visibility is only with the hub.
So in this case 19 is my aerotec 6 repeater
I would recommend you install the “Hubitat Z-Wave Mesh Details“ app from Hubitat Package Manager detailed here:
I have been working on a tool to provide a way to explore Z-Wave Mesh Details. This tool can answer questions like:
Which devices are acting as repeaters?
How many devices are routing through a particular device?
Which and How many devices are in a FAILED state?
What devices are neighbors for a given device?
[mesh-details-0.2.17-beta-filtered]
[mesh-details-0.2.17-beta-details]
I started developing this in ST earlier this year as a weekend project, and now have ported it to HE and have go…
From it, you can easily see if any of your devices use your extender.
