How do I connect my Nest camera to Hubitat?
I'm new to Hubitat. I switched from SmartThings since SmartThings ended their Groovy support, so I'm still getting used to things.
How do I connect my Nest camera to Hubitat? Does the integration no longer work? If that is the case are the any custom integrations from the community that I can use?
Options are limited...did you look at this?
You could also use Blue Iris or Camect to connect them to hubitat.
