I just got the C8 pro elevation. I basically got it to control my Airbnb location so guests can do self check in. I have Alarm.com hubs across all my locations but would love to replace it all with hubitat.
My locks are all Weiser 10 keypad zwave plus locks. I did factory reset on the lock before adding. My issue is that commands sent from the app take forever in some cases 4 hour to execute. And new user and codes constantly fail to add.
Is this a design flaw or am I doing something wrong?
The codes were add via Hubitat Lock Code Manager to add the codes. No VPN. I have a test lock installed in a piece of wood. The lock, Hub( hardwired and computer are all set on a table.
Exclude device( happens instantly)
Include device (takes forever and most times it times out)
Adding name, room and save.
The codes would go from pending to failed. When I click retry the same happens. I'll delete it reset the lock and try again.
Also - which specific model of Weiser lock and Hubitat hub are you working with? I will also reiterate @neonturbo's suggestion to use legacy z-wave for now, instead of ZWaveJS.
