Honeywell Thermostats/Total connect Comfort
Just got my Hubitat plugged in this morning, and can't quite migrate yet since I missed a couple of key components, one of which is my thermostats. I've got two of the Honeywell Wi-Fi thermostats, and don't really want to shell out the money to upgrade them right now. I'm wondering if there's an easy workaround or if TCC integration is on the roadmap?
I think I could get away with using IFTTT for the short term, but it's a less than ideal solution.
Any ideas from the community?
I certainly don't have an answer, but a comment and request for validation. I always found the ST integration to be unreliable, but IFTTT worked every time. Since TCC is a cloud service, the benefit of a direct Hubitat integration is minimal vs. using a cloud intermediary, such as IFTTT.
If I've misunderstood, I'd appreciate correction.
You're right, I just prefer to limit hops where I can. I've also found IFTTT to be a bit on the slow side when triggering things. IFTTT will work.
I have a few honeywell wifi t-stats I'd like to at a minimum poll (and if I'm honest control) heating mode(on/off), current temp and set point. I do some very basic turning on/off of fans/etc based on this info and it's always nice to see more info in fewer apps as well as set them from a single action.
If anyone's making any progress on such, I'd rather cooperate (ride along) with that effort than do it badly on my own.
The API looks pretty straight forward (I also have a T-Series).
https://developer.honeywell.com/content/t-series-thermostat-guide
When I get some time, I might try to log it's traffic. Would be nice if there were a local option.
Definitely looks like a cloud only solution unless Honeywell has an obvious unprotected Firmware feature...or if there is a physical link between controller micro and a separate TCP/IP controller. Might peak under the hood but generally not worth the time.
Plan to go the cloud route or buy a replacement dumb controller (that the family can use with buttons) with a local interface that is already supported. Zen?
