HomeSeer HSM200 on Z-Wave JS
Thanks for the help
I switched to the built in driver as you suggested. Unfortunately it does not allow any control of the LED (only gives motion state, temperature and illuminance). If I recall correctly, that’s the reason for using the community driver instead.
Here is the driver I had been using for several years. The discussion in first post is likely related to why it’s not working on Zjs. Apparently it does not use the Switch Color command class
I’m no longer able to change the color of the LED using the community driver above. Turning it on/off isn’t an issue.
I can do some testing and check the logs this week
