All devices are still working in Hubitat but they do not work in HomeKit. This is using the new beta app.
I’ve removed the integration and rebuilt and re added it in HomeKit several times. My HomeKit should be running the new architecture.
I noticed the issue yesterday afternoon. The only environmental change made was that I added a new Apple TV. To the mix. I made sure to update the Apple TV to the latest firmware but that didn’t help.
Any direction at all would really be helpful. I’m also running the latest available firmware.
I’ve already power cycled my Apple TV, but I have multiple and several home pod minis when I kill one the the environment just shifts to another device. Are you recommending killing all Apple devices for 5 min then powering back on to see if it resolves the issue?
@tonywc - There’s an extensive thread over here. This started happening to me after I updated to the new architecture, and for some reason it was a motion sensor causing the issue. I could be coincidental that it started with the Apple TV.
I turned on relaxed security and everything started working. What is going on with that? How much do I compromise my security by flipping that switch on? Will this be something we can turn back on once the 16.2 architecture mess is resolved?
The relaxed security skips some parts of a handshake routine between a HomeKit home hub (Apple TV or HomePod) and Hubitat hub. In theory, if there's a HomeKit home hub on a local network that hasn't previously been paired with a Hubitat hub, that home hub could still control Hubitat devices.
Yeah, it's a temporary workaround until 16.2 issues are fixed.
