I am having trouble upgrading Homebridge plugins and now I get an error message when I try to upgrade Homebridge itself. The error is:
USER: XXXXXXXXXXX
DIR: /usr/local
CMD: npm install -g homebridge-hubitat-tonesto7@latest
execvp(3) failed.: No such file or directory
Command failed. Please review log for details.
It is the same error for both Hombebridge and the plugins.
I've looked on the web but don't understand the solutions they suggest.
I have it running on a Mac mini running OSX 11.2.3.
Any ideas how to fix this? Should I just reinstall it? Thanks in advance
I wish I knew the answer... However, you will probably get better results posting this question in @tonesto7 's dedicated thread to this Homebridge plugin. Should be lots of users there that might know the answer.
[RELEASE] Homebridge Hubitat v2.0
I'm happy to release the new version of my homebridge-hubitat-tonesto7
Upgrade Notice:
Due to the changes in the plugin API (switching from legacy to dynamic) you can not directly update the plugin, you will need to add as a new accessory and setup your devices/automations/scenes again.
On a positive note, you can use the same Hubitat app instance as long as you update it to the latest code.
Changes
Plugin
[NEW] Completely rewrote the entire plugin fromβ¦
Did you install the Homebridge UI? If yes I have recently started using it to upgrade Homebridge itself and Tonesto's plugin.
Yes I use the UI. I've been upgrading plugins and the Homebridge through the UI without any problems... until recently
I reinstalled node JS and NPM. this fixed the problem.
system
Closed
October 11, 2022, 9:41pm
6
