I’m interested.
Nice, I'm interested. Am I correct in assuming that it will be possible to remove capabilities/attributes at the Hubitat app end and not in the Homebridge config file?
Count me in as well! Would love to test this out.
Awesome, thank you for your response. Very interested.
Hi -
Doing a fresh build today and seeing this in the log ....
[10/26/2020, 17:24:42] [Hubitat-v2] Hubitat-v2 Plugin is not Configured | Skipping...
config.json looks correct to me; thoughts?
I haven't officially released 2.4 yet.
I figured I might be jumping the gun.
Thank you for the great work!
I was going to release tonight but i'm seeing some weirdness with fan speeds that I want to sort before releasing
I'm having the same issue as @jimwaid, is there a way to download a previous version of the homebridge plugin until you release the new Hubitat app?
I'm not sure why npm is installing a beta version, but I'm working on the last few bugs in the new version and should have it released before this evening.
How did you know it was my birthday?
Quick question. Do this plug-in allow the use of buttons in HomeKit? The other plugin versions do not. Thanks!
Getting an interesting output on the homebridge with the hubitat plugin: "[Hubitat-v2] INFO: powerSource: undefined"
Any idea's why it would say this?
That’s my bad. It’s a leftover debug output that I forgot to comment out. It’s completely harmless
Lol. Let me answer your question with a question.
How do you visualize buttons working under HomeKit?
What do I visualize them to look like, physically, or what would I visualize using them for? I have it integrated with my RadioRa 2 system which uses buttons for scenes. Would be great to have a button in HomeKit I could map to a button push on a Lutron keypad or Pico.
@mikepalmer-vnd and @tonesto7 - I’ve implemented several of those as ‘retractable switches’ - basically a switch that turns on and then auto turns off after a second or two.
If it (kinda) looks like a button and behaves like a button - it must be a button
A few months ago I upgraded my Starling hub (Nest integration with HomeKit) and a button popped up. It's used for automations so you can do an action when the front door button is pressed. That was before I upgraded to IOS 14. Now, that button is gone and am guessing buttons were never really supported with HomeKit. Bummer.
@9369292f1992a7d0e654 , Thanks for the suggestion.
I have just enough knowledge to be dangerous.
Homebridge V2 was working after I did the last update everything crashed .
Here are the error and Jason file. Anybody tell me what I am doing wrong?
11/24/2020, 12:41:10 PM] Loading 2 platforms...
[11/24/2020, 12:41:10 PM] Error loading platform requested in your config.json at position 1
[11/24/2020, 12:41:10 PM] Error: The requested platform 'Hubitat' was not registered by any plugin.
at PluginManager.getPluginForPlatform (/usr/lib/node_modules/homebridge/src/pluginManager.ts:224:15)
at /usr/lib/node_modules/homebridge/src/server.ts:387:37
at Array.forEach ()
at Server.loadPlatforms (/usr/lib/node_modules/homebridge/src/server.ts:374:27)
at Server.start (/usr/lib/node_modules/homebridge/src/server.ts:153:29)
at cli (/usr/lib/node_modules/homebridge/src/cli.ts:80:10)
at Object. (/usr/lib/node_modules/homebridge/bin/homebridge:17:22)
at Module._compile (internal/modules/cjs/loader.js:1063:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
at Module.load (internal/modules/cjs/loader.js:928:32)
"bridge": {
"name": "Homebridge C862",
"username": "0E:85:AF:57:C8:62",
"port": 51377,
"pin": "704-35-511"
"accessories": [],
"platforms": [
"name": "Hubitat",
"platform": "Hubitat",
"app_url_local": "http://192.168.0.156/apps/api/",
"app_url_cloud": "thhps://cloud.hubitat.com/api/e82041e7-a7f8-4461-95ea-74b6785a16dd/apps/",
"app_id": 533,
"app_platform": "Hubitat",
"use_cloud": false,
"access_token": "dd35dc80-a53e-46d7-9ab1-ad7fe905a1cc",
"temperature_unit": "F",
"validateTokenid": false,
"logConfig": {
"debug": false,
"showChanges": true,
"hideTimestamp": false,
"hideNamePrefix": false,
"file": {
"enabled": true
"name": "config",
"port": 8581,
"platform": "config"
