I am wanting to use Apple Homekit app to control lock on door, garage door etc. So i did some searches on here to read up on about it.
I do have AppleTV so that will be my remote hub if I understand from what I read here and that I will also need to set up a Homebridge
I have a RasPi which was formally running Home Assistant before I brought Hubitat that I could reformat to use for as a homebridge.
I notice there are several way to install Homebridge on Raspi even there is an app on Apple store which cost 7 dollar to do it for you.
My question is does it matter what method you choose to install Homebridge on Raspi with work with Hubitat or is there is specific installer i need to use for Hubitat?
That app on Apple store make it look easy to install and configure homebridge on Raspi, anyone tried the app? is it worth the 7 bucks?
Take a look at HOOBS. It is a very easy way to install and manage HomeBridge on a Raspberry Pi. You can download a free image to load on a SD memory card. It really makes it simple. If you like it, consider making a donation to keep HOOBS supported for a long time.
You’ll want to use @dan.t’s Hubitat Maker API HomeBridge plug-in. It works very well.
